Need help with offsets
Old Jan 28, 2006 | 01:48 PM
4 Door Skyline's Avatar
Exclamation Need help with offsets
OK guys....I have an 05 Sedan 5AT
Question is: will 20 x 9 and 20 x 10 with 38 and 42 offsets respectively work?
if not, what are the maximum sizes and offsets. Im looking at a set of Maya STM wheels with these offsets.
Thanks in advance guys.
Old Jan 28, 2006 | 03:57 PM
twinturbozs's Avatar
They'll look a little sunk in. You would probably want offsets somewhere in the 20-30 range for those widths.
Old Jan 28, 2006 | 04:21 PM
well im looking for a deep lip on them....
im not to good with offsets so if anyone can shed some light on the info, please do
Old Jan 28, 2006 | 06:42 PM
codeflux's Avatar
it will rub both front and back - you will need to roll your fenders.
Old Jan 29, 2006 | 08:23 AM
ok so what offsets do you think i should run for those sizes
Old Jan 29, 2006 | 11:46 AM
vodkarocket's Avatar
Modded Member
Please refrain from giving any more advice.
The offsets you posted won't work. A couple members have been able to run 9's in the front with the right offset, but it required more than 3 degrees of negative camber to fit. In terms of fitting the 10" wide rears, you would have to have an offset between 49-52 to make it fit.
Go for the more conventional 8.5"/9.5" staggered combo- there will be much less hassle down the road.
Old Jan 29, 2006 | 05:11 PM
Thanks Vodka,
Now thats an answer I can use.
Old Jan 31, 2006 | 01:00 PM
Sorry, for the bad info, i thought it was for a coupe.
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
