Replaced brake pads
Replaced brake pads
i just replaced my pads with hawks. I have to step on it half way it order for it to start braking. Why is that? resurface rotor? bleed the brake fluids? help me out here guys! thanks!
I Just Ordered Project Mu B-force Front Pads For My 03 Sedan From Project Nissan.com-$93.50 And The Stock Rotors From Trademotion.com-$78.39 Each, For The Front. Are There Any More Parts Needed To Be Ordered Before I Take My Car For Installation?like Brake Fluid, Brake Lines, Etc.? What Does Bleeding Mean ? Is That Changing The Brake Fuid, And If So How Much Fluid Does My Car Need?
If you have the Brembo's, bleeding the brakes should be pretty simple. Google bleeding brakes and you should find a pretty easy set of instructions. With the Brembo's you don't even have to remove the wheel. If you don't have a tool to help you bleed the brakes, just get a buddy to help.
kinetek
Aug 3, 2015 04:25 PM
