Specific Springs question.
Old Feb 14, 2006 | 04:19 PM
deadmanincbh's Avatar
I am currently looking to purchase some springs as I feel the need to improve the cars suspension. I know this has been asked many times before but some of the answers I found searching was not sufficient enough for my needs. I am thinking about getting 350Z springs as they should improve handling and give me a 1/2in drop. Now the question aries if I do go with the 350Z springs should I go with the newer 04.5+ or the 03. I want something that feel similar to stock when going over potholes and similar stuff but yet want something that give improved handling over stock setup. Now I would also like to know which after market springs also give a 1/2in and offers similar specs to what I am looking for. I looked at the sticky but found nothing too similar to what I am looking for. The RSR for the 350Z sounds like what I am looking for but since I drive an 03 sedan the drop would be more like 1.6in instead of the .6 I am looking for. Any other options? One final note is that the max drop I am looking at is around .8in Thank you.
Old Feb 14, 2006 | 09:17 PM
RBull's Avatar
Rated M
I can speak for the drop with the '05 350Z springs. They did drop my coupe 1/2". There are numerous posters who have stated the drops with earlier Z version springs are not even but I do not have personal experience there. As to other springs I'll let someone with direct knowledge answer you.
Old Feb 15, 2006 | 12:39 AM
Well that is good to know. How do you like the ride of it compared to what you had on there? Thank you.
Old Feb 15, 2006 | 07:04 AM
RBull's Avatar
Rated M
It's hard to do a fair comparison becasue at the same time I changed to Tokico shocks which are set firmer than stock.
I believe the ride on mine would be identical as we measured and the springs were identical in diameter therefore believe the same spring rates. However I think this is only true with Canadian models of 04 coupes that have a sport suspension with firmer springs and shocks.
In any case the ride is great.
G/L
Old Feb 16, 2006 | 12:54 AM
Thank you. Anyone else with a suggestion?
Old Feb 16, 2006 | 01:27 AM
drunkin master's Avatar
I installed the espelir gt springs that drop .5 inch all around. Ride quality is not that much different than stock. On the freeway, it feels alot better than stock. I had the springs intalled just about two weeks ago and the springs are just about settled. I might have to cut my rear fenders though, I rub when I take the turns a bit hard. I don't have to cut them because I don't see myself making turns like that all the time. My wheels offset has to do a lot with it. Good luck on the purchase.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
