need answer fast, tein s-tech allignment specs
Old Feb 19, 2006 | 02:59 PM
Sasanpasta's Avatar
I just lowered my car yesterday and the allignment is all f'd up. i called just tires to do an allignment today and they said they couldnt do it cuz they dont know the specs for the lowered car. does anyone know what allignemnt specs are, or where i can get the specs, for an 04 coupe with tein s-tech spring and stock shock?
thanx for the help
Old Feb 19, 2006 | 03:48 PM
kenchan's Avatar
take it to a more reputable shop. just try to get close to factory specs (to start off).
Old Feb 19, 2006 | 06:03 PM
Sasanpasta's Avatar
Allignment Shop
Can anyone reccomend a reputable allignment shop near Encino, Ca?
Old Feb 24, 2006 | 10:11 PM
Klubbheads's Avatar
No shop will do it unless u tell them that u dont want the factory settings.
Ask them to do with some negative camber, they will be able to do it.
Old Feb 25, 2006 | 09:33 AM
Q45tech's Avatar
Important to understand:
Alignment is actually STATIC MISALIGNMENT, a setting that at highway speed and load sets the tires correctly. Assuming oem design and new suspension bushings.
When you change geometry you create bump steer from tie rod angle change.
Generally tires work the best with a static negative 0.50-0.75 camber setting.
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
JoeMac
Sep 28, 2015 12:28 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
NJ6MT
Sep 10, 2015 08:40 AM
