Brake Distance
Old Feb 26, 2006 | 10:47 AM
Godfather's Avatar
Brake Distance
i was on the highway, going 120km (miles?). All the sudden i had to stop due to traffic up ahead, i noticed when i pushed hard on the brakes, the car started vibrating and took time to stop. For a Sec i was sure i was going to hit the person ahead but i was 2 inches away from the guy ahead in the stop. My car just jamz when i apply brakes when the car is going slow, it only vibrates when stoping from high speed. am i the only one with this problem or is there a way to prevent this problem again? do i need to upgrade my brakes and if do which onces? If i'm going on the highway and i have to stop all the sudden i dont think i can stop from what i seen. My foot was all the way down and still i couldnt make the G stop.
Manbir
Old Feb 26, 2006 | 12:03 PM
kenchan's Avatar
im guessing you're not talking about the ABS pulsing through the pedal, but
your cars physically vibrating through the brakes...right?
if so, i think you may need to get your rotors resurfaced (turned) and
pads checked.
Old Feb 26, 2006 | 12:38 PM
RBull's Avatar
Rated M
I would agree. If the vibration is mostly in the wheel your front rotors are the likely culprit.
Old Feb 26, 2006 | 01:04 PM
Godfather's Avatar
alright thanks, I will have a look at it soon as my father comes home tonight.
Manbir
Old Feb 26, 2006 | 03:49 PM
Q45tech's Avatar
The spec for rotor runout is 0.001" ,....looking doesn't tell you much, you must measure.
http://www.slaetechs.com/browseprodu...INT-GAUGE.HTML
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
