Brembos.. Grease/Lube?
Old Feb 21, 2006 | 01:10 AM
Derek173's Avatar
Is there any high temp grease or lube you can use to lube the pistons and other parts of the calipers?
Old Feb 21, 2006 | 06:57 PM
L454's Avatar
The brake pistons should be lubricated by the brake fluid. You could use wheel bearing grease, but what parts of the brake system are you trying to lubricate?
Since you have a fixed caliper brake system I do not see a need to lubricate any of the parts.
Old Feb 21, 2006 | 08:08 PM
GonSpeed's Avatar
lithium grease works
Old Feb 22, 2006 | 01:12 PM
superchargedg's Avatar
silicon brake lube for moving or sliding parts,moly based brake lube for the back of the pads to reduce noise,never use lithium grease or wheel bearing grease on the brake system and do not over lube.
Old Feb 24, 2006 | 09:03 PM
L454's Avatar
Actually superchargedg is right you should not use wheel bearing grease or chassis grease in a brake assembly since it might run onto the friction surfaces when the temps get high. I guess all of us have some off days.
Old Mar 1, 2006 | 03:54 AM
lolyouidiot's Avatar
nice
LxV Socal
Nov 24, 2012 11:04 PM
crazynuts16
Steering & Suspension
Jul 27, 2012 05:17 PM
Footballmania32
Jun 8, 2012 03:14 AM
DRKNYT
May 1, 2012 08:17 PM
a0alvl
Dec 7, 2006 04:59 AM
