is it necessary to resurface rotors when changing pads?
Old Nov 19, 2012 | 04:55 PM
LxV Socal's Avatar
My friend goes to school at UTI and he is going to align and change my break pads for free but he told me he already passed the class where they let you resurface the rotors..i was wondering if its necessary to resurface,if it is I guess I can take them off the next day and take them to a shop to get that done
Btw I have brembos..
Old Nov 19, 2012 | 05:46 PM
superchargedg's Avatar
Its not required but new brake pads need a fresh surface to bed into for max performance and no noise.
Old Nov 19, 2012 | 06:39 PM
TemjinX2's Avatar
Not required but if you don't your pads will wear out unevenly
Old Nov 19, 2012 | 08:00 PM
partyman66's Avatar
That's a pretty general statement to address an issue that really needs to be addressed on a case-by-case basis.
It depends on the condition of your existing rotors at the time of the pad replacement. Some rotors (based on their condition) should be turned on a brake lathe to even up the braking surfaces, some rotors are not technically capable of being turned since their factory runout measurements will put them out of spec if you use a brake lathe on them(as is the case with the factory-equipped Brembo rotors on some G35's), and sometimes the rotor wear is very even and uniform and it's just not necessary to lathe or replace them.... and you just slap some new pads on and go. I usually end up not having to resurface my rotors, but there have been times where the rotors on some of my older cars that I've owned were in sorry shape and I just replaced them. A lot of it depends on your driving/braking habits and the environment in which you drive.
Old Nov 19, 2012 | 08:41 PM
gary c's Avatar
Depends, if the rotors are running true and within specs you can get by with scuffing them with fine sandpaper to remove residue. Then do the "bed in" process after your pads are installed. (search)
Gary
Old Nov 19, 2012 | 08:51 PM
TemjinX2's Avatar
Its a general answer because its a general question. Also it costs around $20 generally to resurface rotors, so it would be foolish not to take the extra precaution especially when it cones to brakes and given the cheap cost.
If there blanks generally you can resurface the rotors at least once if there under 30k. You can't resurface slotted and drilled rotors.
Old Nov 19, 2012 | 11:26 PM
LxV Socal's Avatar
How do you know when u need new rotors?
Old Nov 19, 2012 | 11:54 PM
TemjinX2's Avatar
there's a set thickness that the rotor needs to meet in order to be able resurface. Once the rotor becomes too thin you cannot resurface.
Old Nov 20, 2012 | 12:55 AM
dofu's Avatar
20 Year Member
It's not required but much better to. Also scrub and clean the crud off the brackets before lubing everything up as well.
Old Nov 20, 2012 | 01:37 AM
totopo's Avatar
The rotors have the minimum thickness stamped on the edge. Measure it with a caliper.
Also no, you don't have to turn your rotors when changing pads. Especially if you are keeping pad material the same, ie oem to oem.
Old Nov 20, 2012 | 01:23 PM
osuav8r's Avatar
I've just slapped new pads on several different vehicles and never had a problem. That's assuming they don't have significant runout problems or deep groves or anything. I think you'll be fine if they're in decent shape.
Old Nov 20, 2012 | 01:40 PM
VMRWheels's Avatar
Not necessary but depending on the condition of your rotors it would be recommended.
Old Nov 24, 2012 | 09:03 PM
LxV Socal's Avatar
Is there a certain type of grease/fluid I am supposed to apply to the stoptech street break pads I ordered for my brembo calipers? I am finally changing them tomorrow,my current ones are DONE.
Old Nov 24, 2012 | 09:21 PM
osuav8r's Avatar
You don't need any fluid or anything, but clean the rotors off with some steel wool and brake cleaner to remove the factory protective coating
Old Nov 24, 2012 | 09:28 PM
HereKittyKitty's Avatar
ideally...........yes! If not , then buy new ones..........IMHO!
