Semi-Metallic or Ceramic
Old Feb 22, 2006 | 03:07 PM
JuicedAthletics's Avatar
Replacing the pads tomorrow.. Can someone tell me what differences I will notice between the two? I dont track my car.. its a daily driver with Brembo's
Old Feb 22, 2006 | 04:52 PM
D87's Avatar
D87
Semi-metallic gives you longer-life pads (and I understand because of the harder material they will also be harder on your rotors than "Regular" pads). Ceramics are good because they are lower on brake dust. I'm waiting to get these as the OEM pads have so much dust they are driving me nuts.
Old Feb 22, 2006 | 06:54 PM
da45king's Avatar
I always talked about getting hawks...but I used wagner thermo quiets with the bembros....they lasted 40k(with excessive aggresive driving).....I just replaced the fronts again with the same pads....lifetime warranty the pads were free..this time.....they originally cost me $27......hawks $99 vs free...no complaints and dust is a none issue.
Old Feb 22, 2006 | 06:57 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
+1 on the wagner thermo quiets, we use them at my work and they're great.
-GP-
Old Feb 22, 2006 | 07:37 PM
DHCrocks's Avatar
from my experience ceramic has way less dust but not as much bite. Semi-metalic seems to give a better bite. When I switched over to ceramic pads on my car I could def. tell the difference. They are now more linear in feel, no more touchy super sensitive brakes. The initial pedal depression is no longer jerky. But the down side is braking distances are longer. Get ceramic only if you want to cut down on the dust.
Old Feb 22, 2006 | 08:16 PM
i went with the wagner thermo quiets.. ill let u know how they work on the brembos...
thanks guys,,,
Old Feb 22, 2006 | 11:55 PM
Derek173's Avatar
Satisifed makes replacement pads for the brembos and they are great! They dust very little and I have used them on the track and on the street. Pad feel is the same as stock but almost no dust! You can get them at tire rack for $25.
Ceramic pads arent that great, I would stay away from them if you plan any aggressive driving.
Jiggerjuice
Dec 6, 2015 10:29 PM
NailBomb
Oct 28, 2015 07:53 AM
wuppiedog
Aug 7, 2015 11:16 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Nismoboy
May 21, 2003 07:05 PM
