OEM Sports Suspension and Stillen Sways
Mar 8, 2006 | 06:44 AM
I would like to know what would be a good setting for my sway bars. I was thinking maybe going with front - med and rear - med. What are you guys' settings on your Stillen sways.
Reply 0
Mar 8, 2006 | 12:17 PM
do a search and you should find lots of info on settings. good luck.
I think people are happy with med/med
Reply 0
Mar 8, 2006 | 03:15 PM
I had a similar set up to you, Sedan w/ Sports Suspension.
I had my set at med/med when I installed the sways. It improved handling quite a bit.
Reply 0
Mar 9, 2006 | 09:35 PM
Because the springs on the 06s are so stiff, I would not recommend going past the medium setting. If you go full stiff, like I have on my 04 with the softer rear springs, your back end is going to get real loose.
Reply 0
Mar 20, 2006 | 03:15 PM
i got front - soft. rear - medium
Reply 0
