Car shimmy's on the freeway? help!
Old Mar 14, 2006 | 12:16 AM
boe's Avatar
boe
well im sitting on tein flex's dropped all the way down, with 10.5 rear wheels on the back. My car shimmy's on the freeway! whenever i change lanes i hit one of those dividers my car wobbles on the back? can some help me out on this one? i have new tires and it is properly balanced. I can't figure out whats causing the problem
Old Mar 14, 2006 | 12:20 AM
drunkin master's Avatar
I would go and take it back to where you installed the flex for you. Maybe they can help...
Good luck.
Old Mar 14, 2006 | 12:40 AM
boe's Avatar
boe
they checked everything and everything was bolted tight. I also forgot to mention i have eibach sways, Front and rears!
Old Mar 14, 2006 | 01:01 AM
Chico's Avatar
Your problem could be a number of things. But based on what you're describing it sounds to me the alignment is not right. Your "toe" might be out too much.
Old Mar 14, 2006 | 01:06 AM
boe's Avatar
boe
hmmm maybe i should try another alignment?! i had it aligned 3 months ago..
Old Mar 14, 2006 | 01:42 PM
boe's Avatar
boe
anyone else can chime in on this? much appreciated, thanks
Old Mar 14, 2006 | 01:54 PM
kenchan's Avatar
^^ +1
Old Mar 14, 2006 | 03:31 PM
VQ35DEJ's Avatar
u need to balance ur tires again, i had the same problem and they didn't catch it until the second time.
Old Mar 14, 2006 | 04:30 PM
boe's Avatar
boe
Thanks for the reply guys!
Old Mar 14, 2006 | 05:36 PM
SFLG35's Avatar
FGC President
i had a similar problem
got an alignment and all was fixed.
i would try gettin another alignment as well as getting your tires rebalanced. that should take care of your problem
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
newg37
Jul 26, 2015 09:32 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Karnicle
Jul 23, 2015 05:08 AM
