Brake Fluid!
Old Mar 14, 2006 | 04:24 AM
jaslui119's Avatar
Brake Fluid!
How much brake fluid does it take to entirely flush our brake system?
thanks...
Old Mar 14, 2006 | 07:25 AM
g35rcr's Avatar
I used about 2 quarts when i flushed the whole system
Old Mar 15, 2006 | 10:25 AM
BeerViper's Avatar
Just used 1 liter last night ... that's with the OEM brembo calipers which hold a bit more fluid than the non-brembo's.
I ordered 1 liter of ATE Super Blue and 1 liter of ATE Typ 200 from raceshopper.com ... then you can alternate colors when you flush again. Both fluids are exactly the same except for color.
Old Mar 15, 2006 | 04:33 PM
shibal_z's Avatar
Reading your sig, and saw that you got the TEIN EDFC installed. Last time I checked, TEIN did not support EDFC for the G35 due to insufficient space for the servos. Did you do some custom cutting to get the servos to fit or has TEIN redesigned their EDFC to fit more cars?
Thanks!
Old Mar 16, 2006 | 06:12 PM
vodkarocket's Avatar
Modded Member
Thanks!
The EDFC system has worked with all Tein coilovers except for the Basic's ever since their inception. It works with the Flex and the CS.
Old Mar 17, 2006 | 03:21 PM
shibal_z's Avatar
I think you misread my question. I know the EDFC system works with the Flex and CS coilovers. What I meant was that last time I checked their compatibility matrix, the G35 was not listed as being supported. This is the additional servomechanical equipment and control unit that bolts on the coilovers to provide electronically controlled ride height adjustments from the dash. I guess I'll check the matrix again.
Old Mar 18, 2006 | 04:20 PM
Modded Member
I think you need to reread my answer. The EDFC has worked on the G35's Flex and CS lines since they were created for our cars. Many people on this forum are running with EDFC on their G35's.
Also, it is NOT to control ride height adjustments, but to control the dampening settings.
seagrasser
May 3, 2022 09:43 AM
MrIP35
Oct 25, 2015 11:13 PM
MThawkins86
Oct 24, 2015 02:07 AM
Blindside360
Sep 18, 2015 09:00 PM
DRG35R
Sep 16, 2015 05:33 AM
