Is the G35 OEM Brembo Caliepr same as the Z??
Old Mar 28, 2006 | 05:41 PM
MahdiG35's Avatar
G RIDIN
HI
I am going to try to get some brembo claipers for my 06 G and I was wondering if the Z OEM Brembo Caliper are the same as the G?? and would they work with my G?
Thanks
Mahdi
Old Mar 29, 2006 | 12:57 AM
StopTech's Avatar
Originally Posted by MahdiG35
HI
Thanks
Mahdi
If it was my own personal car, I wouldn't do that type of brake swap.
The 05+ G35/06 350z have a very different brake system than previous model years. The pistons in the calipers are tremendously larger than before. Larger caliper pistons put out more brake torque. If you were to go to a 03+ OE brembo setup, there would be less brake torque at the wheel. This doesn't function well with the electronic systems such as ABS, Stability control and traction control.
Old Mar 29, 2006 | 01:17 AM
MahdiG35's Avatar
G RIDIN
oh wow I did not even now that!! Thanks for the heads up man!!!! would the 06 350Z Brembo work pretty well with it??
Thanks
Mahdi
Old Mar 29, 2006 | 11:54 AM
StopTech's Avatar
Thanks
Mahdi
Our sources have said that the 06 350z's got the same treatment as the 05 G35's, no brembo option.
Old Mar 29, 2006 | 12:18 PM
Rookie84's Avatar
You won't need Brembos for street driving other than the bling factor. Just get a good set of pads.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
NemesisGee
Aug 11, 2015 07:10 PM
laksjd84
Jul 24, 2015 05:12 PM
mushu
Jul 15, 2015 03:55 PM
