SPC v.s. Battle Version v.s. ?
Old Apr 3, 2006 | 08:40 PM
robertc's Avatar
I'm looking for a camber kit to fix my tire wear problem. Some affordable, but still with good quality that would solve the problem. How's the SPC and battle version kits? Are there any other brands around these prices. Also, will I need to get a toe adjustment too?
Old Apr 4, 2006 | 12:09 AM
mercury3545's Avatar
try www.kinetixracing.com , i bought some from them for my old Z and they worked great
Old Apr 4, 2006 | 01:53 AM
Gsedan35's Avatar
You cannot use the part of the Battle Version kit that adjusts toe, because it requires that you remove the very suspension arm that your oem rear springs sit in. You can only use them if you buy and install a very select breed of coilover, on whose rear springs are located on the rear dampner's and not in the oem location.
In any event you did pick the only two setup's that correctly adjust rear toe from the proper oem location, so by default go with the SPC kit.
Old Apr 4, 2006 | 06:04 AM
silvernole12's Avatar
I put spc camber rods and toe bolts..and they worked great
Old Apr 11, 2006 | 07:42 PM
Drecksel's Avatar
I believe the battle version camber arm can be used with the stock suspension arm, it's their toe bolt that requires you to remove the stock arm.
Old Apr 11, 2006 | 10:28 PM
jwebb82rez's Avatar
SPC lower camber arms and toe bolts. If you call SPC direct the list on them is $200/set (a set is one camber arm and one toe bolt), so you need two total (so around $400) unless you only want to do one side JK. I called IAP Direct (Import Auto Performance) because they had an auction on Ebay for $200 buy-it-now for both sets, I thought it was a typo, it WAS NOT A TYPO. I paid $228.95 total for both. I think they are a forum sponsor up in here
Old Apr 12, 2006 | 01:04 AM
Gsedan35's Avatar
Your correct, I edited my reply.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
Claudiu
Sep 26, 2015 01:04 PM
