05/06 brake qusetion. Need help
Old Apr 3, 2006 | 10:09 PM
mykmar10's Avatar
I have a great deal on a full set of 05/06 350Z brakes (rotors, calipers, brackets, pads and brake lines). Will they bolt up to my 04 G coupe?
Old Apr 4, 2006 | 10:05 AM
mykmar10's Avatar
bump
Old Apr 4, 2006 | 12:43 PM
StopTech's Avatar
Most brake issues usually start with "I got a great deal on ..."
Old Apr 4, 2006 | 01:18 PM
dklau33's Avatar
I'm guessing you are talking about the revised non-brembo oem brakes right? If so, yes they should bolt up to your G. The only bad thing I don't like about the new, bigger, non-brembo brakes is that the aftermarket pad choices are zilch. Only Hawk HPS and Axxis Ultimates I think.
Old Apr 4, 2006 | 04:01 PM
mykmar10's Avatar
I sent you a PM. Please read it and hit me back. Thanks
Old Apr 6, 2006 | 02:14 AM
StopTech's Avatar
There is the limited amount of pad selection but pad manufacturers will be making more as time goes on.
The other issue with putting the 05/06 G35 brake system onto the older cars it that since the calipers have much larger pistons, the pedal throw will increase making it seem like there is a soft pedal. The stability control systems may not function properly as more fluid is needed to operate the calipers.
Cars these days are becoming very complicated and modifications must be chosen properly or the car may end up with performance worse than stock.
Old Apr 6, 2006 | 05:37 PM
myGspot's Avatar
Someone i know works for infiniti and told me that the 05-06 brakes are the same part numbers as the Q45 (not the current but the older one from few years back, the one that looks like the *** got choped at an angle) I'm sure the pads from that one could fit the 05.
I think the caliper should bolt up without any problems as long as you have the mounting brackets from the 05-06. From what i saw on my cars the 2 seem to have identical mounting points.
Old Apr 6, 2006 | 09:00 PM
hayaku's Avatar
StopTech's 13" 4 wheel kit fits '03 to '06 for sure. I bought the kit when it was marked as '03/'04 and it fit properly on my '05, so that means the mounting points didn't change. They will physically fit, but if StopTech says to watch out, I'd listen.
Old Apr 7, 2006 | 01:38 AM
mykmar10's Avatar
Thanks for the replies.
To the guy from Stoptech, I met a guy who has actually done the swap on his 03 G35 and it works just fine. When your 4pot front and rear kits are installed these problems don't happen so why would they happen from Nissan factory parts? To install your kits, you don't have to change the master cylinder or power booster. Just do the install of the kit, bleed the lines and bed in the pads.
Old Apr 7, 2006 | 08:45 AM
SFLG35's Avatar
FGC President
i put 05 brakes on my 03 g and they work just fine.
my buddy has an 05 and he drove my car after i put the brakes on and he said that my pedal feels stiffer than his.
Old Apr 11, 2006 | 01:27 AM
StopTech's Avatar
You don't need to change the MC or booster because the pistons in the calipers are specifically sized for the 03/04 mc and booster. If I have time, I'll bring out some specs of the calipers for you guys to compare.
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
