Settled on wheels, now a 1" drop?
Old Apr 15, 2006 | 08:51 PM
oviwon's Avatar
I don't see where you posted the specs of the wheels. Size, width, offset and tire size.
From what I can see you would do well to drop your G a bit.
245/35/19 +35 offset. It looks like it could hit even if I were to roll the fenders. I just want to here it will be fine from someone and then its dropped.
Old Apr 15, 2006 | 09:08 PM
skeleton_cru's Avatar
Sedan
That set-up should not rub. Remember, when you drop your car you will get a little negative camber which will help avoid rubbing.
Old Apr 15, 2006 | 09:12 PM
Sedan
Originally Posted by absolutg
definitely true but it also screws with your odometer and your speed will always be off.
The 245/40/19 tires were the closest to stock tire height in my case, so I have very little speedo error.
Old Apr 15, 2006 | 10:37 PM
cea020's Avatar
So here are the new wheels. Do I need the drop? If it is lowered an inch will it hit?
It looks good now without the drop IMO. What kind of wheels are they?
Old Apr 16, 2006 | 12:47 AM
oviwon's Avatar
They are TSW Exclusive wheels. Discontinued now and got a sweet deal because they were.
I went to the 350z forum to get springs and will be getting low mileage springs (under 5K). Hope this works out!
Thanks for the help!
Old Apr 17, 2006 | 01:28 PM
jimmyc13's Avatar
Not sure if it's the photo or not, but it looks like your air pressure is low...just a suggestion you may want to check it....
Are those tires the Generals? Tread on side is like no other that I've seen on a high perf. tire....
Old Apr 17, 2006 | 02:51 PM
oviwon's Avatar
Can't beat the price of the generals! $500 vs $1200 was a no brainer especially with the reviews on the generals.
They actually ride really nice, a bit loud but so far so good.
Old Apr 18, 2006 | 12:36 PM
jimmyc13's Avatar
T1-R's are about $210 each....Goodyear Eagle F1 GS-D3's are more in the neighborhood of $1200 or more (total). Good luck w/ them
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Soumilg
Jul 18, 2015 12:33 PM
