Settled on wheels, now a 1" drop?
Old Apr 12, 2006 | 09:06 PM
oviwon's Avatar
I got a 04 or maybe a 03.5 non sport suspension. Is that based on the manufacturing date? The door says 09/03.
I bought some 19x8.5 with 245/35s all around. I haven't installed yet as I just purchased. From what I have been reading it sounds like I should drop it about an inch to look right. The easiest and cheapest is the 350z route I guess but I don't know exactly what I need to buy.
Can someone spell it out for me please so I can start the purchasing?
Old Apr 13, 2006 | 01:44 AM
skeleton_cru's Avatar
Sedan
You should really search around here and in the Wheel forum. Most of the questions you've been asking have been asked/answered so many times before.
Old Apr 13, 2006 | 02:47 AM
Gsedan35's Avatar
It's not so much that you can get oem Z springs for cheap to drop a sedan 1". It's also that you can get that 1" drop without progressive spring compromises. And without spring rate's that make you wonder who let the chimp into the R&D chair.
Old Apr 13, 2006 | 11:05 AM
transportchef's Avatar
I have the 350z susp and love it. Rides almost like stock(just firmer). I have the 19x8 running 245/35/19 and there still is some gap in both front/back. To almost eliminate the gap you need either (lower)springs or 245/40/19 tire.
Old Apr 13, 2006 | 12:16 PM
oviwon's Avatar
Transport - Thanks for the reply
Do you have a pic? Can you give me the details on what you used? I am confused on what I need from reading other posts. Revised vs unrevised? It seems the standard suspension has different spring rates s well?
2003 - 2006 - G35 sedan non sport spring rates - 283/308
Am I supposed to get '05 350z struts with front 03 Z springs and rear 03 G coupe springs?
Old Apr 13, 2006 | 01:59 PM
dyenboy's Avatar
Registered
If you are plannin to swap out the whole struts and springs..
I go with the 05 350z.
Old Apr 13, 2006 | 05:11 PM
jimmyc13's Avatar
It's too bad you already bought your tires...I went w/ 19x8.5 w/ 245/40's all around. Fills up the fender gap more (larger O.D. than OEM wheels) & eliminated the need for me to drop my car. IMO, I LOVE the looks (amt. of gap in fender) with this setup, and I was able to avoid having to drop it. Though there are some members who will always say "now you gotta drop it to finish off the look". IMO, it's perfect & eliminates extra cost & wear & tear on the shocks.
Old Apr 13, 2006 | 07:44 PM
ttrank's Avatar
Grocery getter
H&R !!!
1.2F 1.0R, does not sag in the back like my friend's sedan with eibachs and the performance is great.
Old Apr 14, 2006 | 01:06 AM
oviwon's Avatar
Are the H&R shocks for $240 all that is needed then?
I just swap the shocks and I am dropped an inch? No adjustments to be made? I don't know much about suspension and don't want to get over my head.
If that is it, sweet!
Old Apr 14, 2006 | 04:36 AM
Sedan
You'll need an alignment after any drop.
Old Apr 14, 2006 | 06:31 AM
jimmykce1's Avatar
I believe you will need to get adjustable cambers, correct me if I am wrong.
Old Apr 14, 2006 | 09:39 AM
Sedan
You don't have to get adjustable camber arms. You may experience some negative camber in the front, but not so much with only a 1" drop.
Old Apr 15, 2006 | 05:47 PM
oviwon's Avatar
So here are the new wheels. Do I need the drop? If it is lowered an inch will it hit?
Attached Thumbnails Settled on wheels, now a  1" drop?-p1060695.jpg   Settled on wheels, now a  1" drop?-untitled-1.jpg   Settled on wheels, now a  1" drop?-p1060698.jpg   Settled on wheels, now a  1" drop?-p1060694.jpg   Settled on wheels, now a  1" drop?-p1060697.jpg
Old Apr 15, 2006 | 08:27 PM
Sedan
I don't see where you posted the specs of the wheels. Size, width, offset and tire size.
From what I can see you would do well to drop your G a bit.
Old Apr 15, 2006 | 08:32 PM
absolutg's Avatar
workin...
definitely true but it also screws with your odometer and your speed will always be off.
