350Z Tien H Techs...Drivers side settled lower then passangers side.
Old Jul 30, 2008 | 10:02 AM
  #31
jlin615's Avatar
For those of you with 0.5in difference in the rear, the difference would be 0.25in when you have full tank. I wouldn't bother trying to fix it, it's just the weight of our car, unless you do the springmount mod.
Old Jul 30, 2008 | 12:18 PM
  #32
mesias's Avatar
Originally Posted by sliderg35
From the Eibach Teck Tips:
"Properly index your springs. If your suspension does not specify the clocking of the springs, be sure to index the spring, both left and right, in the same direction. This will ensure the car's ride height will be even left to right. "
I will have to ask the dealer if he did this...
I read this also and i don't get to understand what's the indexing of a spring is. Any ideas?
Old Jul 30, 2008 | 09:44 PM
  #33
Salsaw's Avatar
I took mine back to the dealer and had them check it out to see if it was something as simple as rotating the springs. The said they couldnt because they spin them till they lock into place when they install them, So they said they werent able to help me out. I dont have a fat girlfriend, So I put a couple bags of concrete that I had sitting around at my house on the passengar side on the floor. Im going to roll with it for a couple of weeks so see what happens.?
Old Aug 1, 2008 | 12:27 AM
  #34
jigahus's Avatar
I had them put on last week. They look like the perfect drop with my setup.
Old Aug 1, 2008 | 04:23 PM
  #35
mesias's Avatar
Definitely is about the weight distribution in the car. For those with progressive springs in rear like me is worst. Today i drove like 20 min highway to get my stock 17' wheels replaced for coupe 19". When I got to the place I noticed the weight of the wheels inside of my car leveled the rear springs. So try putting some weight in the higher side for a while.
Old Aug 1, 2008 | 04:44 PM
  #36
gary c's Avatar
Dropped on Tein 350Z H-Techs....!
I must have done something right, my garage is perfectly level....I measured
from the floor to the fender lip. Both fronts are 26 1/4" and the back sides
are exactly 1" higher at 27 1/4"! There's not a 1/16" difference between either side, either I'm lucky or the $ I paid for the install/alignment was worth
every dime! There was an inch taken off the bump stops just like the instructions recommend....
Gary
Old Aug 1, 2008 | 05:22 PM
  #37
jlin615's Avatar
Anybody else cut the bumpstop when installing the springs?
I didn't
Old Aug 1, 2008 | 06:14 PM
  #38
Salsaw's Avatar
you get a more accurate measurement if you measure from the fender lip to the center of the wheel. Then tire pressure isnt a factor.
Old Aug 6, 2008 | 05:11 PM
  #39
jayremix's Avatar
i had my htech installed and have the same problem, anyone had the solution to this?? im thinking of modifying the rear mount on the passenger side...
Old Aug 6, 2008 | 06:37 PM
  #40
jlin615's Avatar
How are you guys' alignment specs?
Old Aug 6, 2008 | 11:11 PM
  #41
Salsaw's Avatar
Im off a .02-.03 degree all the way around on camber.
Old Aug 6, 2008 | 11:39 PM
  #42
mesias's Avatar
these are values "within" specs. I'll probably take the car for re-alignment to get close to nominal values.
FRONTS: (Left Right)
Camber: -0.6 -0.7
Caster: 8.1 8.3
Toe: 0.03 0.05
SAI: 4.7 4.1
Cross Camber: 0.2
Cross Caster -0.1
Total Toe: 0.08
REAR: (Left Right)
Camber: -1.2 -1.1
Toe: 0.09 0.09
Old Aug 7, 2008 | 12:22 AM
  #43
jlin615's Avatar
You two have camber kits? Those number looks VERY good.
Old Aug 7, 2008 | 02:23 PM
  #44
jayremix's Avatar
ok yesterday i noticed the uneven rear passenger side, earlier today i filled up full tankk and the drop is now even.. wtf. anyways, i was planning to cut the bump stop to even it out and now im thinking if i cut it.. wouldn't it mess up my camber on the right whenever i'm at full tank?
Old Aug 7, 2008 | 04:07 PM
  #45
jlin615's Avatar
I think full-tank makes a difference in alignment. I did 2 alignments within a month period, one with half tank and another with full tank. With full tank I alignment came out worse.
