Questions on Tein's CS and Camber
Old Apr 20, 2006 | 12:44 AM
spoiled808177's Avatar
Here's my setup. 05 coupe with 19x9.5 Volk Sf Challenges, 19x10.5...bought a set of Tein CS...will I have camber issues? I also bought the SPC rear camber kit too...Now do I need to put them on or am I better off selling the camber kit? Looking to perserve my tire life and I currently have tananbe NF springs on but they are going to go once the Tein arrive.
Any help is appreciated THANKS!
Old Apr 20, 2006 | 12:49 AM
Alan's Avatar
it all depends on how much you lower it. if you plan on going a lot lower, keep the kit and look into some front A arms.
Old Apr 20, 2006 | 12:52 AM
Where is the safe zone on how much I can lower it? can I go all the way down?
Old Apr 20, 2006 | 11:11 PM
Alan's Avatar
definetly not. its hard to say as it varies from car to car. if you use the arms and kit i would think you can dip down pretty low. you just gotta experiment.
Old Apr 20, 2006 | 11:36 PM
dubs's Avatar
The only issue you will have is with the front camber... The best way to solve this is also the most expensive... the 350 evo A-arms will get your front back into spec & the rears should not be an issue with the spc kit... I have the same exact setup but will have it installed in 2 weeks. I can let you know how it works out for me...
Old Apr 21, 2006 | 06:09 AM
silvernole12's Avatar
He will also have rear camber issues. I'm all the way down in the rear and needed to correct the rear camber/toe with a SPC kit if I wanted to save my tires.
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
NohoG35revup
Aug 22, 2015 12:13 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Soumilg
Jul 18, 2015 12:33 PM
