Is this item a good deal? http://cgi.ebay.com/ebaymotors/TOKIC...temZ8061315142
I was also planning to get 06 350Z shocks does anyone know how well this setup will work? Or shoud I be going with their spring sets also as listed here?
http://cgi.ebay.com/ebaymotors/TOKIC...temZ8059500114
Thank you.
Thank you.
D-spec shocks when used within their spring rate limit's are a outstanding product what once installed and driven on will have you totally understanding why you spend every cent that you did. Can't say the same for some more expensive coilover products offered for the platform.
Now, on the Tokico shock and spring setup for the G, I have to ask. Do you drive a coupe or a sedan? How much drop do you want? And how important is improving performance beyond just from the shocks themselves?
Well I have mentioned before I drive a sedan with a sports suspension and would like a 1in drop at most hence I was thinking about geting 06 350Z springs. Also, if it makes a difference I have 06 sport coupe sways installed. But I currently only plan to install the shocks with my current setup. Thank you.
Anyone also know if there is a better or similar deal on the shock set?
