350z springs on 2005 non-sport suspension question
Old May 3, 2006 | 09:45 AM
darnelled's Avatar
I have been searching posts and reading everything I can find on using the 350z springs or other suspension to lower my car and cannot find a definitive answer. I have the 2005 sedan with non-sport suspension ( reported spring rates of 283/308) on 17 oem rims/tires and would like to lower about 1inch front and rear when I get new rims/ tires. I will likely get 18-19" rims and tire sizes that will keep the speedo accurate.
All I can find is how to use 350z springs on a coupe or sedan sport suspension. I'd like to lower by the cheapest route, avoid rubbing and too harsh a ride quality. Can I use these springs or do I need an entire suspension package? Which ones are recommended for my G?
Thanks
Old May 3, 2006 | 11:45 AM
absolutg's Avatar
workin...
u'll need the entire Z suspension.
Old May 3, 2006 | 08:29 PM
vrsc's Avatar
^^^+1
Old May 3, 2006 | 10:27 PM
Gsedan35's Avatar
Oh I'll give you a definate answer. I flat out do not recommend to run oem Z springs with the non sport suspension. I could see G35 Tein H-tech's or Eibach prokit's (the developement car for the sedan pro-kit was a non sport car). Of course the best solution would be to locate a entire oem 04.5+ 350Z suspension (springs and shocks).
Old May 4, 2006 | 08:55 AM
vrsc's Avatar
Listen to him, he is the suspension guru
jsimonk
Dec 22, 2023 03:49 PM
wuppiedog
Aug 7, 2015 11:16 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
