Nedd Help on camber kit
Old May 7, 2006 | 01:37 AM
smoke1's Avatar
I just bought a set of 20" rims with 255-35-20 tires.
tried them on the front to be sure before buying.
did not try the rear ???
I left the shop at 7.00pm (they were already closed) and I discover at the first agressive corner that they are rubbing the rear fender. they also rub at any major bump.
Shop is close on sunday and I won't be able to return over there for at least 10 days.
I check tonight for a rear camber kit.
Following my calculation I need about 2 degrees of negative camber to have the wheel 25mm inside to clear the fender.
What do you think?
Does some of you have install the camber kit and how far can you gain with the fender?
thanks in advance to help
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
