Will springs really ruin your ride?
Old May 8, 2006 | 04:41 PM
Gorgie1985's Avatar
hey whats up guys....i just got an 06 g35 coupe.......i want to lower it but i really do not want to lose the ride at all..rides real smooth....will adding springs ruin it?.... any suggestions on which brand to get?
Old May 8, 2006 | 04:51 PM
sen_jen's Avatar
Meatshake Enterprise
certain brands will ruin it. choose from Tein, Tanabe, Espelir, RSR, and Eibach.
Old May 8, 2006 | 05:17 PM
Hexxum001's Avatar
If you already have the sport suspension, Teins won't be too much stiffer than that. I have Tein S Techs on my G and it is just a bit stiffer. I can't comment on the other springs though.
Old May 8, 2006 | 06:15 PM
truplay8's Avatar
THE BATMOBILE
no but bags will
Old May 8, 2006 | 06:46 PM
GLuXuRy's Avatar
over time your struts will go bad... someone correct me if im wrong
Old May 8, 2006 | 06:52 PM
blazinZ's Avatar
hotchkis 350z springs. how much of a drop u want??
Old May 8, 2006 | 07:03 PM
superdds's Avatar
you're exactly right...if you lower your car with ANY springs and keep the stock struts, they will go bad eventually. oem struts werent designed to handle the additional compression of aftermarket springs. obviously if you go with something that lowers more aggresively like tein s techs or eibach sportlines, the wear will be sooner than later.
Old May 8, 2006 | 07:27 PM
absolutg's Avatar
workin...
look for linear not progressive springs with rates that aren't much higher than stock and your ride quality will not be compromised very much (and your struts will not wear out much faster)
Old May 8, 2006 | 07:50 PM
superdds's Avatar
agreed...linear all the way. i'd go with 350z tein h techs... the g35 h techs have too soft of a spring rate for the rears.
Old May 8, 2006 | 10:41 PM
FenixL1P's Avatar
or go with 05+ oem 350z (revised) springs.... they should lower the coupe about 1/2 all around.... you'll keep stock spring rate.......
Old May 9, 2006 | 01:37 PM
kenchan's Avatar
get springs with rates in the mid 300lbs/in. that'll keep it nice and comfy.
Old May 9, 2006 | 09:21 PM
stnwag0n's Avatar
I bought s-techs for my sedan and have been holding off installing because i havent picked up shocks yet. Would revised or unrevised 350 shocks be able to handle the compression of the sedan stechs? would they provide a decent ride? would i be better off with dspecs?
Old May 9, 2006 | 09:38 PM
Boston's Avatar
Fenix, I like this option. That said, this will have no other premature wear rate on the OEM struts and no need for camber kits?
Old May 9, 2006 | 09:57 PM
vrsc's Avatar
Here's a total run down on oem spring rates and drop amounts
2003 oem 350Z springs 314/342
2004 oem 350Z springs 314/342
2004.5+ oem 350Z springs 314/427
2004+ oem 350Z roadster* springs 314/427
2003-2005 G35 coupe all car's delivered from the factory with oem 17's or 18's regardless of build year 314/342
2005 G35 coupe when delivered with oem 19's 314/427
2003-2005 G35 sedan without sport suspension 238/308
2003-2005 G35 sedan with sport suspension 314/342
If oem 350Z springs are run on a G35 coupe you will get a 1/2" drop
If oem 350Z springs are run on a G35 sedan you will get a 1" drop**
If oem G35 coupe springs are run on a sedan you will get a 1/2" drop***
Notes
*Unlike 2004 350Z coupes where midway into the model year Nissan revised the suspension, all 2004 roadster's have the revised suspension and all have the higher
Just match them up and go from there
Old May 9, 2006 | 10:48 PM
Boston's Avatar
Notes
VRSC....thanks much! I appreciate the info.
