H tech spring question (help a n00b)
Old May 9, 2006 | 03:22 PM
mswc's Avatar
Crucial dude
I've been searching the board for information, I don't know a whole lot about suspension and such. It looks like the Tein H-tech is the way to go for keeping the suspension as OEM as possible with more of a drop. I'm running the stock 18"s, and I think I will for the next year or so. With the H-tech, I won't need to change the struts or anything like that will I? Are there any long term ill effects using the H-techs? After a few months I'll need to get my alignment checked out right?
I don't need a crazy suspension system, so after reading the reviews these seem to be the way to go.
Old May 9, 2006 | 03:27 PM
GLuXuRy's Avatar
1. No you dont have to change your struts... but they will go bad after time... the stock struts are not made for lowering springs.
2. You can wait around a week to get your alignment (i think most people do it after a week)
3. Most people go with Tokico D specs when they get a strut and spring combo
Myself i plan on getting springs once my wheels come in... but after a few months of saving im going to buy coilovers
Old May 9, 2006 | 03:57 PM
superdds's Avatar
i'd consider going with the 350z h tech's. the g35 h techs are a little soft in the rear and will introduce significant understeer to your car.
Old May 10, 2006 | 11:02 AM
PEPPY's Avatar
I have th g35 h-techs with d-specs. Rides great with alittle more performance. You can feel it in the turns, also the softer spring rates in the rear are a plus, the weight is shifted to the back end when you step on it, you can feel the rear wheels dig in. If you go with the d-spec make sure to install the damper screw extensions before assembly. Fully damper adjustable, so you can have over/under steer to your liking.
Old May 10, 2006 | 12:06 PM
escobar929's Avatar
IMO the g35 h-tech are way too soft in the rear and is gonna make your car understeer like crazy, if you want something that will handle similar to stock but a lil lower, then def go w/ 350z h-techs
Tein H-tech 350z (linear springs)
Spring rates in lbs 358/375
Stiffer then oem by F+14% R+11%
Transfers +3% roll stiffness to front
Lower's G35 coupe by .8"/.7"
Lower's G35 sedan by 1.3"/1.2"
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
Spring rates in lbs 324/260
Stiffer/softer then oem by F+ 5% R-22%
Transfers +27% roll stiffness to front
zcherub
Aug 27, 2015 09:47 AM
joel extreme
SOCAL Meetings & Events
Aug 7, 2015 03:09 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
