Eibach Pro Kit
Old May 16, 2006 | 01:26 AM
05skylineG's Avatar
Eibach Pro Kit
Do you need a camber kit if you get this kit with the stock 19" wheels??? Also, would I need to get a camber kit if i got 20's down the road or would it be the same senario for the stock wheels? I wnat the tire life to still last long. Thanks David
Old May 16, 2006 | 06:50 PM
Toptoneone's Avatar
yes you will need a camber kit! I had to replace all my tires and install a camber kit.
Old May 16, 2006 | 06:53 PM
Toptoneone's Avatar
https://g35driver.com/forums/wheels-tires/97792-kinetix-camber-kit-review-pics.html
here are some pics of my ordeal
Old May 16, 2006 | 09:29 PM
05skylineG's Avatar
cool thanks. Is the eibach kit good for a camber kit?
Old May 16, 2006 | 11:55 PM
Toptoneone's Avatar
yes. the ride is still pretty decent. not alot different then stock. but handles alot better.
Old May 18, 2006 | 04:31 AM
G35BASTARD's Avatar
Are you riding on stock shocks?
Old May 18, 2006 | 09:25 AM
phenom1011's Avatar
I'm having the pro kit installed on mon. and my performance shop said I didn't need a camber kit? That would be more money for them if I did need it. Now I'm confused.... someone please explain. By the way I have 19" axis hiro's
Old May 18, 2006 | 09:39 AM
G-MAN (CANADA)'s Avatar
[QUOTE=phenom1011]I'm having the pro kit installed on mon. and my performance shop said I didn't need a camber kit? That would be more money for them if I did need it. Now I'm confused.... someone please explain. By the way I have 19" axis hiro's[/QUOTE
Good luck I'vs been trying to find that out for months, best trhing is to try doing without and see how the wear is on the tires.
Old May 18, 2006 | 11:25 AM
Toptoneone's Avatar
When I had my eibachs installed they said I shouldnt need a camber kit either. When I went to have it aligned they said no camber adjustment on infiniti g35 so they cant get it into specs. 6 month later my tires were bald on the insides.
Old May 18, 2006 | 11:29 AM
TLS's Avatar
TLS
Toptoneone: which was has more wear, the front or the rears?
Old May 18, 2006 | 11:52 AM
Toptoneone's Avatar
they were both pretty bad.
Old May 20, 2006 | 10:28 AM
phenom1011's Avatar
Would you mind telling me how much the camber kit costs and how much to install? Also is it a difficult job that a performance shop has to do or can I have say, Firestone do it?
Old May 20, 2006 | 01:24 PM
kenchan's Avatar
^ there's many varieties to choose from. the install itself is very easy
and self explanatory. but you must get an alignment after you install
it....so having firestone do it might be a good thing, since most of their
shops have alignment racks.
Old May 20, 2006 | 01:41 PM
ttrank's Avatar
Grocery getter
You do not "NEED" a kit to install the springs but your tires will wear out on the inside faster. I have always kept some negative camber on my cars due to my driving style but I do go through tires quickly. I am going to get a kit for the rears because 275/30's are not cheap and I would like to have better traction for launches.
All in all they are a good idea but depending on what tires you run ($ vs $$$) they may not be worth all the money if you use less expensive tires it would take a while to make up for the cost. I would expect the F&R kits with install and alignment to be somewhere between $900-1,000...
Old May 20, 2006 | 06:18 PM
mynismoG35's Avatar
would u need a camber kit for 350z h tech springs for our G's
