Power Slot Rotors for the G35 Sedan and Coupe
Old 09-28-2006, 01:18 PM
Invision G35's Avatar
Cool Power Slot Rotors for the G35 Sedan and Coupe
Excessive heat can cause resins in your brake pad to vaporize or "outgas." As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surfaces and inhibits performance. Here's where Power Slot's slotted brake rotors make a big difference.
Power Slot's exclusive Vac-U-Slots are machined into the rotor and help evacuate gasses and dust, shed heat, and keep the brake pad surface clean. And in wet, raining conditions, our Vac-U-Slot helps push water off the braking surface for better stopping power.
The Vac-U-Slot also serves as a visual wear indicator. The slot is machined to the rotor’s minimum thickness where it crosses the outside edge. If you cannot see the slot along the outside edge, the rotor has worn down to its discard depth
http://powerslot.com/pages/slot_app_infiniti.html
1/02-8/02----without Dynamic Control System [562 Psl & 562 Psr / 563 Psl & 563 Psr]
8/2002-2004----coupe W/ Mt & Sport (w/ 4 Piston F/ Caliper) [564 Psl & 564 Psr / 565 Psl & 565 Psr]
8/2002-2004----coupe W/ Auto Trans [562 Psl & 562 Psr / 563 Psl & 563 Psr]
8/2002-2004----sedan 2wd [562 Psl & 562 Psr / 563 Psl & 563 Psr]
2004-2005----sedan 4wd [562 Psl & 562 Psr / 563 Psl & 563 Psr]
PM for Pricing!!!
CA resident subject to pay tax.
Old 11-21-2006, 05:48 PM
Trik69's Avatar
Can you PM me with a price for an 04 Sedan.
Old 11-22-2006, 12:36 PM
emtguy05's Avatar
can you PM with price on 8/2002-2004----coupe W/ Mt & Sport (w/ 4 Piston F/ Caliper) [564 Psl & 564 Psr / 565 Psl & 565 Psr] to 91915. How much for the front pair, and how much for the rear pair. Thanks
Old 11-24-2006, 09:57 PM
nshah82's Avatar
Will it work with brembo kit?
Old 11-27-2006, 02:22 PM
yes it does work w/ the brembo calipers
Old 12-06-2006, 05:22 PM
edandolo's Avatar
PM for pricing for rear rotors. 2003 w/brembo calipers.
thanks
Old 12-11-2006, 04:57 AM
NicNoobie's Avatar
pricecheck
Hi, can you please PM w/ price for 2003 sedan (non-brembo):
Thanks!
Old 12-13-2006, 10:02 AM
doyle's Avatar
PM Price on '03 Coupe Auto F&R..Thanks!
Old 12-13-2006, 01:57 PM
NicNoobie's Avatar
Do you sell brake pads too?
Hello,
Going to buy a set of rotors, but wanted to know if you sell the Project Mu B-Force brake pads (front and rear) for G35 sedan (non-brembo). If so, can you let me know the cost please...thanks!
Old 12-18-2006, 10:08 AM
Insane's Avatar
can you PM me Price for front and rear for an 03 sedan to 79936
Old 03-13-2007, 06:23 PM
RST531's Avatar
PM for pricing for front & rear rotors. 2004 w/brembo calipers
Old 03-19-2007, 03:46 AM
pass2srf's Avatar
Please PM for price on front and rear 2004 w/ Brembo.
Old 04-04-2007, 11:07 AM
G2FAST's Avatar
front with brembos?
Old 04-21-2007, 07:47 PM
n1cK's Avatar
could you pm price for front/rear w/brembo's ('04 coupe). local pickup is preferred. thanks!
Old 04-23-2007, 06:35 PM
So.Cal.G's Avatar
coupe W/ Auto Trans [562 Psl & 562 Psr / 563 Psl & 563 Psr] both front and rear please 92557 area code
Quick Reply: Power Slot Rotors for the G35 Sedan and Coupe
