Ferodo Brake Pads / SS Brake Lines / JBT Big Brake Kit
Old Dec 1, 2006 | 11:53 AM
RAVSPEC's Avatar
FERODO Brake Pad
Ferodo DS2500 (Street) Performance Brake Pads
- Nissan 350Z/ G35 (Brembo) Front - $119 Shipped
- Nissan 350Z/ G35 (Bremb0) Rear - $85 Shipped
Ferodo DS3000 (Race) Performance Brake Pads
- Nissan 350Z/G35 (Brembo) Front - $179 Shipped
- Nissan 350Z/G35 (Brembo) Rear - $139 Shipped
Technafit Stainless Steel Brake Lines - $159 Shipped
Available Application (Non-brembo or Brembo) * Please Specifiy When Order
DS2500 (Street) Brake Package For G35 / 350Z (Brembo) - $389 Shipped
Package Included: Front and Rear DS2500 Ferodo Brake Pads, Technafit Stainless Steel Coated Brake Lines (DOT Approved), 2 x Motul BF600 Brake Fluid
DS3000 (Performance Race) Brake Package For G35 / 350Z (Brembo) - $499 shipped
Package Included: Front and Rear DS3000 Ferodo Brake Pads, Technafit Stainless Steel Coated Brake Lines (DOT Approved), 2 x Motul BF600 Brake Fluid
DS2500 - Highway Specification
This race developed pad has all the qualities required for a world beating high performance street pad. Its consistent coefficient of friction (0.47) at any temperature low or high gives very predictable bracking and great pedal modulation. This new generation of friction material is very low in compressibility ensuring a firm pedal feel, while still providing great life for both rotor and pad. Combined with the low dusting of the wheels and low noise this product is "the" brake pad for the driver who demands the ultimate in braking performance.
DS3000 - Track / Race Only
DS3000 has set the braking standard since its introduction in 1998. DS3000 has contributed to countless wins and podium positions in many Touring car and GT championships around the world.
DS3000 has
- reduced bedding in time (approx. 50% quicker than other materials)
- extremely high friction level at any temperature or speed
- higher initial bite
- predictability, in all conditions, when bracking into the corner because of the flat
friction curve
- less off brake between the brake pedal and throttle
When using the material with light inertia racing cars, as a general rule it is necessary to apply less brake pedal pressure than you would normally expect. This will avoid overbraking and generation of excessive heat in the braking system and disc. DS3000 is not suitable for road use
Old Dec 1, 2006 | 11:56 AM
RAVSPEC's Avatar
JBT - Big Brake Kit
Designed specifically for sport compact performance cars, the Nurburgring | F1 program from JBT Motorsports utilizes forged piston calipers to provide a true lightweight alternative to most competitors cast platforms. Additional weight savings are provided by titanium alloy pistions, increasing strength while resisting heat & fading. Nurburgring | F1 center disks are slotted, providing air cooling and thermal conductivity that is 40% more efficient than conventional disks.
- 6 Pot , 355 mm Front - $2599 shipped
- 4 Pot , 330 mm Rear - $1699 shipped
(** including Technafit Stainless Steel Brake Lines **)
Full Polish Version Available !! - PM For Pricing !
Old Dec 1, 2006 | 12:25 PM
RAVSPEC's Avatar
Old Dec 1, 2006 | 12:28 PM
ttrank's Avatar
Grocery getter
Do they make a 4-pot front? Most 6-pot kits that I have found won't clear my rims.
Old Dec 1, 2006 | 01:14 PM
RAVSPEC's Avatar
we can get the 4 pot front , but it's 45 days wait time !! let me know if you want us to special order for you !
Old Dec 20, 2006 | 12:17 PM
RAVSPEC's Avatar
quick bump ....
Old Dec 22, 2006 | 03:29 PM
RAVSPEC's Avatar
quick bump ....
Old Jan 12, 2007 | 01:59 PM
RAVSPEC's Avatar
still plenty available !
Old Jan 22, 2007 | 11:45 AM
Rphillips6487's Avatar
im looking to purchase a big brake kit, possibly one of yours, but im curious what is it meant by 4 and 6 pot? Im sure its a dumb question but id appreciate the help
thanks
Old Jan 22, 2007 | 04:24 PM
Diesel1's Avatar
Moderator
4 piston and 6 piston
4 piston caliper you will see 2 "bumps" which are fit one piston on each side. Brake fluid pushes these pistons outward (Out of the caliper) which pushes teh brake pad against the rotor. The 6 piston is teh same but with 3 per side (Inboard and outboard). Generrally speaking, the more pistons, the more force and the more evenly that force is applied resulting in shorter stopping distances.
I am sure more guys can give you the more scientific definition, but that is it in a nutshell!
Old Feb 5, 2007 | 06:33 PM
RAVSPEC's Avatar
quick bump !
Old Feb 7, 2007 | 04:03 AM
cloud's Avatar
will the 350z non brembo SS brake lines work on the 05 G35C?
what's the part number for the SS brake lines for the 05 G35C?
Old Feb 7, 2007 | 12:17 PM
RAVSPEC's Avatar
i got both version for non brembo and brembo G35 !
Old Feb 9, 2007 | 04:29 PM
RAVSPEC's Avatar
quick bump .....
Old Feb 10, 2007 | 12:10 AM
cloud's Avatar
the 03-04 nonbrembos and 05 nonbrembos are a little different but do they share the same brake lines?
