*Special*Rotora 6 piston Front & 4 piston Rear 14" Kit
Old Feb 16, 2007 | 11:00 AM
JT@Z1motorsport's Avatar
Rotora 6 piston Front & 4 piston Rear 14" Big Brake Kit
For A limited Time Only PM for pricing
An excellent package for slowing down your high powered 350Z or G35.
350Z / G35 Rotora 4 wheel front and rear Big Brake Kit
Kit includes:
* 6 Piston front calipers
* 4 piston rear calipers
* 14" (335mmX32mm) piece floating rotors
* Stainless Steel brake lines and all required fittings
* High quality brake pads
Fully cast and CNC machined to ensure the highest quality.
Rotora's high performance brake system enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking. To achieve this proportional front-to-rear brake bias.
Rotora's 2-piece cast aluminum calipers are fine tuned by increasing the clamp load to the optimal level while utilizing the stock master cylinder to retain overall front-to-rear brake bias.
This Rotora high performance brake system is comprised of
* (4) 2-piece slotted directional vane, vented discs (355X32mm) 14" diameter
* high performance (6-piston front) (4-piston rear) calipers (red or blue of your choice)
* carbon steel (S45C) mounting brackets
* Rotora ceramic friction material race pads
* stainless-steel braided brake lines (D.O.T. compliant)
All Rotora brake systems are direct bolt on replacement with minimal modifications required.
FEATURES and BENEFITS:
* Rotora's 2-piece aluminum, heat-treated calipers provide improved pedal feel while increasing the clamp load to ensure equal front-to-rear brake bias.
* Differential piston bore sizes (depending on application) engineered to each specific application.
* Stainless steel braided brake lines prevent brake hose expansion under pressure and improve stiffer pedal feel.
* All Rotoras steel braided lines meet D.O.T. Compliance Standards and pressure tested to meet FMVSS-106 (Federal Motor Vehicle Safety Standards) standard.
* Cross drilled/slotted or slotted rotors to ensure equal heat dissipation for continuous hard braking to resist warping and brake fade while relieving the rotor and brake pad surface free of excess brake dust and debris.
* S45C carbon steel mounting brackets (depending on application) with steel studs to provide added strength. Direct bolt on replacement to the vehicles original suspension.
* Larger rotor surface area compared to stock rotor to utilize the leverage and increase brake torque.
* All systems are ABS compatible.
* All pistons with dust seals.
* All Rotora high performance brake calipers are factory pre-installed.
Calipers available in Blue, Red, and Black (special order).
All 2 piece rotor kits come either cross drilled & slotted or slotted only.
ELIMINATE BRAKE FADE & STOP FAST!
$100 Ground Shipping to anywhere in the Continental US
Old Feb 16, 2007 | 12:08 PM
MaxxT's Avatar
Please PM for price.
MT
Old Feb 16, 2007 | 02:57 PM
ATL_Red_G35's Avatar
^ Oh snap. PM me too please.
Old Feb 16, 2007 | 03:37 PM
rjcs03's Avatar
pm price please
Old Feb 16, 2007 | 03:45 PM
G35SHAWN's Avatar
Very interested..send me a pm with the price quote.
Old Feb 16, 2007 | 07:49 PM
jd2k1's Avatar
A bit pricey if that's the correct price on your website.
Old Feb 19, 2007 | 02:00 AM
v8hunter's Avatar
price shipped to 85225
Old Feb 19, 2007 | 08:18 PM
xjonmo's Avatar
price shipped to 02467
Old Feb 20, 2007 | 12:40 AM
Dieselnuts's Avatar
price to 30039
Old Feb 21, 2007 | 03:20 PM
un33ddisshiet's Avatar
price shipped to 77388
Old Feb 26, 2007 | 02:32 PM
Neal376's Avatar
pm price 11581
Old Feb 26, 2007 | 02:34 PM
Tarheel's G's Avatar
price to 85249. Thanks
Old Feb 26, 2007 | 02:43 PM
D's06G's Avatar
price 33176
Old Mar 1, 2007 | 12:11 AM
JDM7672's Avatar
price shipped to 40245
