Stoptech Front BBK Starting at $2195 Shipped. Add Gruppe-S Rear Brake Kit for $1!!
Old Sep 14, 2007 | 02:42 PM
gruppe-s's Avatar
Former Sponsor
For you guys out there without the Factory Brembos. Feel like you're lacking something? Wheels look bare without big brakes? Here's you chance to fix all that!
StopTech Big Brake Kit
-Shorter Stopping Distances
-Better Brake Modulation, Firmer Brake Pedal
-Better Cooling, Less Brake Fade , Longer Rotor and Pad Life
-Stiffest aftermarket calipers with patented bridge
-Better clamping under hard braking and less pad taper
-Includes Front Caliper, Rotors, Brackets, Pads, and SS Lines
Gruppe-S Rear Brake Package
-Gruppe-S Slotted Rotors
-Made in Europe, not China
-Hawk HPS Pads (For Non Brembo)
-Technafit SS Rear Brake Lines
Combos for StopTech Front BBK and Gruppe-S Rear Brake Package
4 Piston 332x32 BBK Combo- Starts @ $2196 Shipped
4 Piston 355x32 BBK Combo- Starts @ $2696 Shipped
4 Piston 355x35 BBK Combo- Starts @ $2796 Shipped
6 Piston 355x32 BBK Combo- Starts @ $2996 Shipped
Caliper Options
Black, Red, and Silver are Standard Colors
Add $200 for Yellow, Gold, or Blue
Rotor Options
Slotted Rotors with no Coating is Standard
Add $100 for Drilled Rotors
Add $65 for Zinc Coating
(So add $165 for Drilled and Zinc Coated)
*Not all Color/Rotor combinations are available from StopTech. Call or pm for any questions and prices! Rear Gruppe-S Package is not $1 by itself.
Don't want a Big Brake Kit, but need something for your non-Brembo G35?
StopTech SportStop Rotors + HPS Pad Front & Rear Brake Package
-Direct Replacement Slotted Rotors
-HPS Street Pads, quiet with good stopping power
-Brake Hose with SUS 304 Stainless Steel
-Teflon Tubing Covered
-Swivel Fitting Prevent Lines From Binding
-Decrease Stopping Distances by 20%
$525 Shipped
Click here for more Brake Parts on Gruppe-S.com
Old Sep 17, 2007 | 03:13 PM
gruppe-s's Avatar
Former Sponsor
bump!
Old Sep 21, 2007 | 02:30 PM
gruppe-s's Avatar
Former Sponsor
bump!
Old Sep 21, 2007 | 03:54 PM
caligrown's Avatar
2NDL1FE
I don't want a bbk. I do want drilled rotors for my 05 G35 coupe w/ non-brembo brakes... Does StopTech have drilled rotors for my car? How much will this cost? Please let me know. Thanks!
Old Sep 21, 2007 | 05:08 PM
gruppe-s's Avatar
Former Sponsor
The Drilled rotors front and rear by itself will be $349 Shipped.
Old Sep 22, 2007 | 06:47 PM
kenasaki's Avatar
those are factory replacements right? i have an 05 sedan sprt pkg, non brembos i guess. what brand are those?
Old Sep 24, 2007 | 03:01 PM
gruppe-s's Avatar
Former Sponsor
Yes factory replacements, they are stoptech rotors.
Old Oct 13, 2007 | 03:51 PM
2K6G35's Avatar
Do you have a picture of this drilled rotors for G35 w/non-brembo?
Old Oct 15, 2007 | 02:18 PM
gruppe-s's Avatar
Former Sponsor
Old Oct 17, 2007 | 10:00 PM
gruppe-s's Avatar
Former Sponsor
Bump Guys
Gruppe-S
Old Oct 22, 2007 | 08:32 PM
kitsune's Avatar
Will the 6 piston Stoptech front BBK and the 4 piston Stoptech rear BBK fit onto a 2007 G35x sedan?
Mike
Old Oct 23, 2007 | 09:02 PM
gruppe-s's Avatar
Former Sponsor
Mike
AFAIK, The BBK is only made for the 2wd. Let me double-check when Stoptech opens tomorrow to give you accurate information.
Christina
Gruppe-S
Old Oct 23, 2007 | 09:21 PM
kitsune's Avatar
If they fit the g35x I would be interested in a set for the front and rear.
Mike
Old Oct 24, 2007 | 01:39 PM
gruppe-s's Avatar
Former Sponsor
As of right now, they only have the 2wd application available...
Old Dec 26, 2007 | 08:49 PM
gruppe-s's Avatar
Former Sponsor
Bump Guys
