CZP Stock Sized Replacment Brake Kits >>
CZP Rotors:
__________________________________________
Non-Brembo: $625 Shipped
Brembo: $700 Shipped
Description:CZP Brake Kit - Front & Rear Rotors, Front & Rear Hawk HPS Pads, Front & Rear Stainless Steel Brake Lines, and ATE Super Blue Dot 4 Brake Fluid. These kits are stock sized replacements rotors, they are not bigger then stock, because if they were, you would need new calipers to fit bigger rotors.
We only use Centric Rotors(Stoptech Brand), but instead of using a black coat, we Zinc plate them for a cleaner look. The combination of cross-drilled and slotted will give you the best of both worlds. It will dissipate heat and increase bite for better stopping power.
These Rotors are:
Military spec. Plating
Prevent premature warping
Prevent fade
Reduce operating temperature
Reduce stopping distance
Pads:
Hawk Performance HPS compound provides advanced braking characteristics to enhance your driving experience. This unique compound combines the safety and quality of Aerospace design partnered with the braking technology of motorsports.
Features -Extremely low dust
-High friction/torque hot or cold
-Gentle on rotors
-Virtually noise-free
-Much improved braking over OEM
-Long extended pad life
Technafit SS Lines:
Stainless Steel Brake Lines provide a quicker pedal response, maintaining consistent brake pressure and precision brake modulation, especially during threshold braking.
ATE Super Blue Brake Fluid:
ATE Super Blue Racing brake fluid has a dry boiling point of over 530 degrees F, far exceeding DOT 4 standards. Mixes with any other DOT 3 or DOT 4 fluid. Super Blue absorbs moisture very slowly, so you don't have to change it as often as many high-performance fluids. Great for your street car that sees weekend track duty.
These Rotors are:
Prevent fade
Pads:
-Gentle on rotors
Technafit SS Lines:
