Now Available at Gruppe-S.Dont confuse these pads with Standard HPS or HP+ Pads in a different box. These pads are a Brand New Special Compound Designed Exclusively for Peak Performance. Peak Performance HP-PRO™ Brake Pads. Using a secret compound blend formulated by Hawk Performance™, HP-PRO™ Brake Pads offer an extremely high coefficient of friction making these a perfect upgrade over stock for high performance streetcars used in Drifting, Autocross, Time Attack or drivers that experience repetitive, heavy braking. Peak Performance secret compound gives you uniquely controllable torque with smooth consistent feel and bite. This compounds allow for later and deeper brake use into the corners while requiring less pedal effort and shorter pedal reaction times. They do not require significant heat up or extensive bedding (break-in), and have exceptional wear characteristics allowing you to get more laps per set with no warm up required. HP-PRO™ provide superior release and torque control characteristics. HP-PRO™optimal temperature range is 95-1,250 degrees Fahrenheit.
MSRP $149
MSRP $149
