Best BBK for the monery hands down - Wilwood 6/4
Old Jan 2, 2009 | 02:15 PM
ARTrace's Avatar
Brakes Best BBK for the monery hands down - Wilwood 6/4
Track tested - The Best 6/4 for the Money - This is a 100% Wilwood Kit
6 Piston front with Factory 18" Wheels
These are 100% built and backed by Wilwood - not a kit using Wilwood components and custom brackets etc. These have full factory warranties and DOT certifications
The best 6 Pot / 4 Pot Value - These will fit 18" factory wheels and some 17" wheels with the correct offsets
Detailed Description
Superlite 6 Big Brake Front Hat Kits are engineered for use in conjunction with OE front hubs on a variety of competition, show, custom, and sport driving applications. Billet Superlite 6 piston calipers, PolyMatrix brake pads, machined aluminum hats, and 13" GT directional vane rotors exemplify award winning style and provide the ultimate in Big Brake stopping power. Born from Wilwood's 25 year tradition of building championship brake systems, SL6 Big Brake kits are the perfect compliment to wheel, tire, and suspension equipment upgrades.
Billet Superlite 6 Piston SL6 Calipers
Calipers Available in Black or Red:
SL6 calipers are pure performance featuring a fully CNC machined billet body with closed end bridges and a reinforced bridge to body transition. Center bridge body bolts provide additional strength and positive retention of the pads. These elements combine as an ultra-rigid body that resists separation and deflection under high load. Driver comfort and confidence soar with immediate response from a very firm pedal. The SL6 generates high clamping force and balanced pad loading from a race-proven differential bore six-piston configuration. Staggered piston sizes distribute pressure to compensate for the natural variances in temperature, load, and wear rate that occur over the length of the pad. Pad life is extended and performance is measurably improved. Stainless steel pistons are used in all custom show and sport performance applications for their low heat transfer properties and resistance to corrosion. Road race kits feature SL6/ST calipers with Thermlock® pistons for maximum heat protection in extreme heat environments. High temperature, square faced piston seals provide long service life in extreme environments with positive piston retraction on release. Stainless steel SRS bridge wear plates eliminate pad gouging and extend the service life of the caliper. The spring-loaded action of the SRS plates also eliminates pad rattle and dampens the vibration harmonics that contribute to pad squeal. Fluid tubes are dampened to eliminate vibration stress and recess mounted for protection from track debris. SL6 calipers bear Wilwood's signature and a high luster black anodized finish in a style that will catch the eye and win the favor of the most discriminating enthusiast.
GT Series Rotor Hats
GT aluminum hats are lightweight and strong to manage the exceptional brake torque generated by the SL6 Big Brake system. The hats are specially designed for use on OE hubs without modifications or interference to the suspension or ABS components. The hats carry Wilwood's signature and a high luster black anodized finish to prevent corrosion and enhance the overall appearance of the complete package inside the wheel.
SRP or GT Series 13" Rotors
Large diameter vented iron rotors provide substantial increases in cooling and stopping power over small diameter OE rotors. All Wilwood rotors are manufactured from premium grade, long grain carbon iron to provide long wear with high thermal stability and resistance to distortion. The superior heat absorption and dissipation qualities of a directional vane iron rotor are essential to preventing heat fade and realizing the longest service life from the pads and rotors. For custom, show, and high performance sport driving, SRP rotor kits offer the high-tech look and improved performance of a directional cross-drill and face slot pattern. In addition to their aesthetic appeal, the venting and cleaning action of the holes and slots will reduce pad glaze, dissipate surface heat, and minimize irregular pad build-up on the rotor faces. The results are smoother engagement with improved consistency and response at the pedal. Every SRP rotor is treated with a silver zinc wash to reduce corrosion on the areas of the rotor not kept clean by pad contact. GT rotor kits feature Wilwood's ultimate competition rotor with full detail machining, asymmetrical face slotting and individual dynamic balancing. GT rotors run true and vibration free with extended rotor life and pad wear on applications subject to higher sustained operating temperatures.
PolyMatrix Brake Pads
PolyMatrix brake pads get fast response with high resistance to fade, long wear, and the low rotor abrasion that PolyMatrix is so well known for. Specific pad types and compounds have been selected for each application and are listed in the service parts guide for each kit.
Caliper Brackets and Hardware
Aluminum mount brackets are lightweight and strong. Each bracket is CNC machined for precise fit on each specific spindle. Grade 8 strength or higher nuts, bolts, studs, washers, and alignment shims are included with each kit.
Plumbing
Fittings and hoses for most kits must be ordered separately. A few noted kits do include stainless steel flexlines. Otherwise, hose kit part numbers can be found next to each kit in the ordering information.
Old Jan 2, 2009 | 03:03 PM
ARTrace's Avatar
vvvvvvvvvvvvvv
Old Jan 2, 2009 | 04:19 PM
ARTrace's Avatar
bump
Old Jan 2, 2009 | 04:46 PM
citymunky's Avatar
to 23454?
I'm looking to upgrade my brakes soon. Also does it cost extra to get them in red? Would the rear kit alllow me to keep the parking brake?
Old Jan 2, 2009 | 04:51 PM
ARTrace's Avatar
pm sent
Old Jan 4, 2009 | 05:09 PM
ARTrace's Avatar
vvvvvvvvvvvvv
Old Jan 5, 2009 | 06:38 PM
ARTrace's Avatar
bbbbbbbbbb
Old Jan 5, 2009 | 06:46 PM
chord42's Avatar
price to 30328
Old Jan 5, 2009 | 06:54 PM
ARTrace's Avatar
pm sent
Old Jan 6, 2009 | 08:17 AM
ARTrace's Avatar
bump
Old Jan 6, 2009 | 08:35 AM
Nilesh1001's Avatar
shipped to 11367 red calipers and cross drilled slotted rotors
Old Jan 6, 2009 | 08:58 AM
ARTrace's Avatar
pm sent
Old Jan 8, 2009 | 02:23 PM
ARTrace's Avatar
bbbbbbbbbbbbb
Old Jan 13, 2009 | 09:30 AM
ARTrace's Avatar
mmmmmmmmmm
Old Jan 13, 2009 | 01:05 PM
04G35NYC's Avatar
how much shipped to 11209 in red or black? thanks.
