Quote:
1pc Rotors are around 18lbs, 2pc Rotors will be around 15lbs.Originally Posted by OCG35
Coz, how much does the current lightest rear rotors weigh (whether Stoptech, OEM, CZP, whatever) and how much less would you expect 2-piece to weigh?
Coz
GreenGoblin
The goblin resurrection
close
- Join DateOct 2006
- LocationIn my garage
iTrader Positive Feedback100
iTrader Feedback Score(66)
Liked:187 Times in 95 Posts
Buy more parts from Coz, I am working on finding some more income so I can get those 2pc rotors one day.
Quote:
If they ever become available Originally Posted by GreenGoblin
Stupid Vendors.Coz
Quote:
Coz
Coz… so the weight difference between the front (14”) 2-piece vs 1 piece rotor is 10-12 lbs… but the weight difference between 13.8” rear 2-piece and 1-piece rear is only 3 lbs? (nearly same diameter)… I take it that means the front are substantially thicker? Otherwise how is the front variance so much greater than rear?Originally Posted by Coz@Czp
1pc Rotors are around 18lbs, 2pc Rotors will be around 15lbs.Coz
Excuse my ignorance – just trying to make an informed decision here…
^ one reason is the rears still have the internal drum for the parking brake .
Remember, I'm guessing here, as I do not have any 2pc rears to weigh, but yes the rears are thinner, and I'm professionally guessing Originally Posted by OCG35
Coz… so the weight difference between the front (14”) 2-piece vs 1 piece rotor is 10-12 lbs… but the weight difference between 13.8” rear 2-piece and 1-piece rear is only 3 lbs? (nearly same diameter)… I take it that means the front are substantially thicker? Otherwise how is the front variance so much greater than rear?Excuse my ignorance – just trying to make an informed decision here…
Coz
Quote:
Stupid Vendors.
Coz
Stupid Vendors.Coz
Coz, how much for the entire kit (Nissan) with teflon lines, slotted 1 pc rotors, hawk pads, and shipping to 65583? Also alot of people have asked about fitting certain wheels. Have these been installed without any clearance issues on the stock 18 inch coupe rims? Thanks
Jeremy
Jeremy
Quote:
Jeremy
Sure, which hawk pads? I can't be certain on wheel clearance, please use template for that.Originally Posted by jdmitchell1014
Coz, how much for the entire kit (Nissan) with teflon lines, slotted 1 pc rotors, hawk pads, and shipping to 65583? Also alot of people have asked about fitting certain wheels. Have these been installed without any clearance issues on the stock 18 inch coupe rims? ThanksJeremy
Coz
Beebo
close
- Join DateDec 2006
- LocationEl Paso Texas
iTrader Positive Feedback98
iTrader Feedback Score(59)
Liked:205 Times in 182 Posts
Akebono Infiniti G35 Front & Rear 14 Inch Big Brake Kit w/ Stoptech Rotors, SS Lines, and Motul Brake Fluid 03-07 Coupe: $2139
are instructions included on where to cut the dust shields?
Please PM me
Please PM me
Please PM me
Instructions are included, dust shields need to be cut just enough to clear the rotors.Originally Posted by Beebo
Akebono Infiniti G35 Front & Rear 14 Inch Big Brake Kit w/ Stoptech Rotors, SS Lines, and Motul Brake Fluid 03-07 Coupe: $2139are instructions included on where to cut the dust shields?
Please PM me
Coz
Quote:
Coz
Coz, did you complete the install instructions (for adapter bracket)?... when I got my calipers you were still working on them... if they are available can you PM them or are they listed on CZP website?Originally Posted by Coz@Czp
Instructions are included, dust shields need to be cut just enough to clear the rotors.Coz
Quote:
Yup, they are done, PM me your e-mail address and I'll send them over.Originally Posted by OCG35
Coz
