Complete Brake Upgrade Package Offered by RacingBrake
Old Aug 12, 2009 | 08:21 PM
RacingBrake's Avatar
Upgrade two piece rotors for 06-08 non-sport G35
Originally Posted by RacingBrake
To verify their interchangeability or required modification, we would need to test fit this 90371/1 rotor for 9161 cars. (90371/2 are curved vanes while 9161 is a straight vane.) We are raising our hand again for help.
We are committed to offering a complete brake upgrade option for G35/G37 drivers and would make sure the upgrade will meet your expectation for performance improvement, be affordable and yet stay within stock integrity.
Just be aware that brakes for G35/G37 are extremely confusing although we tracked them down very closely. So please be careful in making selections, if you are not so sure on your choice let us know and we will do our best to help, and if you find any errors on our web listing we like to be corrected.
We researched the brake pad and found out the one used on Brembo Caliper (03-04 track) is substantially taller than OE caliper (07-08 non-sport), so we decided to create a new P/N for exact diameter (320mm) and thickness (28mm) to assure perfect fit (rust ring) and also avoid possible mistake resulting from test fit (can mix up on years), but we still like to thank to those PM us offering the test.
We also like to run a pre-order special and see if we can have at least 10 orders before we release the development.
Old Aug 13, 2009 | 12:02 AM
1ILLG's Avatar
How much for Brembo front and back rotors and pads shipped to 32746. obviously shipping being free.
Also need a set for a 350 non brembo.
Old Aug 13, 2009 | 09:27 AM
Can you indicate your model and year to ensure we quote you the correct brakes.
We are updating our website for non-Brembo two piece rotors (P/N 2137; 320x28mm).
Earlier models (03-04 Brembo) two piece has been available (P/N 2016; 324x30mm) here but wait for our announcement later today for un-resistible deal (limit to stock) and of course the shipping is on us if order is received by Saturday 8/15/09.
Since we have to make new discs for non-Brembo, so we need a minimum of 10 pre-orders, same unbelievable pricing as Brembo, no limit for ordering qty but there is a wait of 8-12 weeks. Order by 8/31/09 for free shipping.
Old Aug 13, 2009 | 09:51 AM
1ILLG's Avatar
03 infiniti g35 brembo need rotors and pads
03 350 z need rotors and pads non brembo
and I also just need a set of pads fro a regular 350
all hawks ceramic
Old Aug 13, 2009 | 04:53 PM
all hawks ceramic
PM Sent!
Old Aug 13, 2009 | 05:23 PM
2GoRNot2G's Avatar
I live very close to Fullerton, but unfortunately I don't have the Akebono brakes on my car. Let me know if you guys ever need a '07 - '08 G35 Sport Sedan with the 13" rotors for test fitments... I'd be happy to help out.
Old Aug 13, 2009 | 06:39 PM
g35brandon's Avatar
Do you offer a brake kit (more than likely gonna need rotors and pads) to fit an '03 g35 coupe with brembo, and if so, how much shipped to 33647? Thanks!
Old Aug 13, 2009 | 07:31 PM
Do you need just front or front & rear. We have both one piece and two piece rotors (F&R). Our one piece rotors are made with curved vanes for better cooling.
As to pads, what kind of driving you do most, street, or some HPDE, or track.
Thanks
Old Aug 13, 2009 | 07:33 PM
We appreciate your offer and will keep you in mind when we have the rotors ready for fitment test.
Thanks
Old Aug 13, 2009 | 07:34 PM
Jeff92se's Avatar
Red Card Crew
We have decided to make a new disc to match the OE rotor size in diameter (320mm) and thickness (28mm). This would assure perfect fit.
Dimension (diameter and thickness) can be modified to smaller, but should be done at our factory shop for the tight tolerance and run out instead at aftermarket brake shop.
We later found out other than the dimension difference, the pad height is not the same either, while our rotor ring surface (where pad sweeps), is cut to fit the pad height (rest of area is coated with EDP to prevent rusting), so a new disc is designed, and a pre-order sales price will be offered.
Maxima crowd has made aware of this thread. There are many that use the 6th gen 12.6" rotors and calipers as an oem upgrade to their 3gen-4thgen and 5th gen maxima also. So you would be speaking to these guys also
Old Aug 14, 2009 | 12:59 PM
Wes_888's Avatar
I just ordered myself rotors & brake pads!!
great G35driver discount!! THANKS!!!
Old Aug 14, 2009 | 02:20 PM
robbdogg's Avatar
2005 G35c
rotors and pads (hawk ceramic) shipped to 77057
TIA
Old Aug 14, 2009 | 02:49 PM
Originally Posted by robbdogg
2005 G35c
TIA
PM Sent!
Old Aug 14, 2009 | 05:06 PM
For 2003-2004 Infiniti G35 (Brembo) & 2003-2008 Nissan 350Z (Brembo) models we are now offering a two piece rotor sale, please click here if you are interested in purchasing a set:
https://g35driver.com/forums/brakes-...e-pricing.html
Old Aug 14, 2009 | 07:15 PM
  #30
Just a reminder, FREE SHIPPING promotion ends on 8/15/2009, place your orders in!
