FS: FS: 13.6" Wiwood BBK light 2-piece set front brake complete 03-06 Z & G + 05 G35x
SOLD --13.6" Wiwood BBK light 2-piece set front brake complete 03-06 Z & G + 05 G35x
***********Brakes are SOLD****************
Haven't been active in modding my G35x for a while,
my Wilwood BBK just came off my car (05 G35x).
The two piece rotors has very little wear, amazing!. pads were worn but I have a spare set (2 new/2 lightly used pads). (I pair them up, slightly used for in-side & new pad for outside on each caliper)
See the brake set-up on my car:
http://www.cardomain.com/ride/807724/2005-infiniti-g
See the model where I purchased it a few years ago:
http://www.fastbrakes.com/product_p/...g35%2013-4.htm
You can call them up to see it it'll fit your car.
I paid ~$1600 total originally, asking about half, which is $795 Reduced to $699 Now $599
+$60 shipping in the US of A. (Will ship in 2 separate boxes). Paypal gift only. (Papal goods OK but add 4% or $37 PP fees)
email me at ma_sha1@yahoo.com for questions if I am not
active enough to get back to you on time.
Everything are there including the calipers (pained blue), rotors, pads, SS lines, mounting plate adapters. Its actually 13.6" & will fit 18" wheels or larger. may need spacers.
Disclaimer:
I am not responsible if some bolts or screws are missing, was told by shop everything is in the bag. Not responsible or if it doesn't fit your car, so do your research up front. Spacers may bee need ed depends on wheel off set. I used 20mm spacer on my 18" PPIAA & 10mm spacer on my 18" Enkei wheels. It's best to test & then get spacers for it if needed. They are used. Selling as is, no returns, no refunds.
Disclaimer:
The manual says 03-06 Z & G but doesn't say what model. You might want to call fast brakes.com & ask about fit for the model in the 2nd link.
05 G35X has same brake as 04 2WD sedan. 05 2WD sedan has slightly larger rotor than 04 2wd sedan but still much smaller than 13.6". If 05 vs. 04 sedan has same mounting mechanism, then the BBK would fit. I.e. if 05 sedan brake fit 04 sedan, then the BBK would fit.
I am actually running the same brakes on my coupe with a smaller rotor and have enjoyed them, this is a great deal for an entry level setup
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
