FS: ** 6 Piston Red Rotora Front Big Brake Kit ** SD CA
Old Mar 11, 2012 | 04:20 PM
chomorro's Avatar
Thumbs up ** 6 Piston Red Rotora Front Big Brake Kit ** SD CA
Im from my350z.com my name is Chomorro over there with excellent itrader. I was told this kits fits a g35 by one of your members here who removed it for me
Up for sale is a sweet rotora bbk kit off an 03 350z. The brakes dont get used the way it should be, since i havent been FI for three years. Hopefully one of you guys could use them.
No shaking or vibrating. Brakes work perfect, still have plenty of life left on the pads. AS an added bonus i will throw in a BRAND NEW set of Hawk HP pads for them. These are the Crossdrilled and Slotted Rotor version.
A fellow member will install this set for you for $100 bucks if your local to San Diego.
$1700 Shipped Or Best Offer. Full kit Stainless lines, and extra new set of HP pads
Here is a description of what this kit is:
Rotora 6 Piston 14" Front Big Brake Kit
An excellent package for slowing down your high powered 350Z or G35.
350Z / G35 Rotora 6 piston Front Big Brake Kit
*6 Piston front calipers
*14" (355X32mm) 2 piece floating rotors
*Stainless Steel brake lines and all required fittings
*High quality brake pads
Fully cast and CNC machined to ensure the highest quality.
Rotora's high performance brake system enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking. To achieve this proportional front-to-rear brake bias.
Rotora's 2-piece cast aluminum calipers are fine tuned by increasing the clamp load to the optimal level while utilizing the stock master cylinder to retain overall front-to-rear brake bias.
This Rotora high performance brake system is comprised of
*a set of 2-piece slotted directional vane, vented disc (355X32mm)
*a set of high performance (6-pistons) calipers (red or blue of your choice)
*carbon steel (S45C) mounting brackets
*Rotora ceramic friction material race pads
*stainless-steel braided brake lines (D.O.T. compliant)
All Rotora brake systems are direct bolt on replacement with minimal modifications required.
FEATURES and BENEFITS:
*Rotora's 2-piece aluminum, heat-treated calipers provide improved pedal feel while increasing the clamp load to ensure equal front-to-rear brake bias.
*Differential piston bore sizes (depending on application) engineered to each specific application.
*Stainless steel braided brake lines prevent brake hose expansion under pressure and improve stiffer pedal feel. All Rotoras steel braided lines meet D.O.T. Compliance Standards and pressure tested to meet FMVSS-106 (Federal Motor Vehicle Safety Standards) standard.
*Cross drilled/slotted or slotted rotors to ensure equal heat dissipation for continuous hard braking to resist warping and brake fade while relieving the rotor and brake pad surface free of excess brake dust and debris.
*S45C carbon steel mounting brackets (depending on application) with steel studs to provide added strength. Direct bolt on replacement to the vehicles original suspension.
*Larger rotor surface area compared to stock rotor to utilize the leverage and increase brake torque.
*All systems are ABS compatible.
*All pistons with dust seals.
*All Rotora high performance brake calipers are factory pre-installed.
Calipers available in Blue, Red, and Black (special order).
All 2 piece rotor kits come either cross drilled & slotted or slotted only.
ELIMINATE BRAKE FADE & STOP FAST!
A=42mm
B=201mm
C=122mm
All info taken from here where the kit sells for $2400
http://www.z1motorsports.com/350_g35...oducts_id=2042
CLEARS OEM WHEEL ACCORDING TO THE SITE
Old Mar 11, 2012 | 06:41 PM
Tslider's Avatar
ill give ya 1500 shipped, shoot me a pm if ya wanna make it happen
Old Mar 13, 2012 | 07:30 AM
chomorro's Avatar
PM coming your way.
Old Mar 13, 2012 | 06:20 PM
serturbo's Avatar
Aaah so so tempting... I wouldve taken these off you hands and I'm in San Diego but not sure if I'm keeping my car or going FI.. Good luck w sale though
Old Mar 13, 2012 | 06:36 PM
chomorro's Avatar
Well i guess you could always install it use it and then take them off and sell them yourself hahah. Your fellow g35 driver here does the install on the cheap so its not too bad.
Just let me know, i have lots of interest but of course its not easy coming up with money. I do accept credit card through paypal
Old Mar 15, 2012 | 12:07 AM
chomorro's Avatar
Pending Sale
Old Mar 15, 2012 | 07:20 PM
chomorro's Avatar
sold
Frankieg35
Mar 20, 2016 09:42 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
kinetek
Aug 3, 2015 04:25 PM
Ashton35
Jul 17, 2015 10:11 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
