Buying, Selling & Leasing Discussion Interested in getting a G35? Ask your questions here! (No Classified Posts)
Need advice on buying g35x
Old May 26, 2011 | 07:03 AM
amateur's Avatar
I will be moving to NY soon and I decided to go with a g35x since I wanted AWD ,a sporty ride. Although I like MT I can do without it.
Let me briefly state my expectations :
-- I want to be able to put in around 15K miles per year and keep the car for at least 2 years.
-- It should be fun to drive and good on snowy weather conditions.
-- Front seats should be comfortable for several hour trips.
-- Maintenance cost should be low. Now, my previous vehicle was a BMW so I am not expecting a toyota like no maintenance cost, but it should be reasonable. If it is like $2K+ a year I will simply look elsewhere.
Planning to buy the car for less then $10K and having several thousand dolars at hand if anything goes wrong. Also I am looking for 2003-4 if possible, around 100K (Early 100K so that the first major maintenance has been done like changing water pump). But I am not familiar with g35 very much.
I will use this as my daily driver, I expect the mechanical components to work properly, other things need not be in perfect condition.
I will appreciate any advice, tips
thanks
Old May 29, 2011 | 04:12 PM
sssmasss's Avatar
u can buy a g35 coupe for 10k with 100k.
i dont have a G but have i a Z. The engine are the same anyways. The maintenance is nothing. It is ridiculously low. i spent less than 500 dollars a year on maintenance. unless u have to change tires then it would run over that amount.
My cousin have a G and the maintenance is low too. if u dont abuse the G then it will last forever man.
it is a japanese made anyways
Cajuncowboy
Jun 21, 2021 09:47 AM
miata007
Aug 17, 2015 04:36 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
iknowitsfast
Aug 12, 2015 02:08 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
