Buying, Selling & Leasing Discussion Interested in getting a G35? Ask your questions here! (No Classified Posts)
2004 g35x with 150,000?
Old Aug 18, 2012 | 11:28 AM
Tvpinballs's Avatar
Hi,
New to the forum. I am looking at a 2004 g35x with 150,000 miles. Car has no leaks and runs strong. 2nd owner with some records. He will take $5000 for it. Is this a good deal and what do I need to look for? Thanks, Todd
Old Aug 18, 2012 | 11:58 AM
AuAltima3.5's Avatar
See if he changed the transmission fluid and transfer case fluid.
Compression rod bushings, lower control arm bushings, and bad sway bar links are the usual suspects when G shopping for an 03/4 model. Also, if the stereo won't work or the A/C is stuck on or off, it'll need a new radio or JDM double din kit to fix.
I think maintenance has alot to do with longevitiy. The rest is design.
I haven't heard of crazy issues with Gs and high miles. There are quite a few around here over 200k.
Old Aug 20, 2012 | 01:01 PM
G35xTurbo's Avatar
I have an 04X with 125K and it runs strong as hell. That doesn't seem like a bad price if the title is clean. I would probably want about $8-9K for mine with 125K on it.
Old Aug 20, 2012 | 07:11 PM
binbin's Avatar
I have 155K miles(bought with 125K) on my G35 coupe, and I am a spirited driver. Just make sure you do the oil changes and whatever maintenance. Problems I had to deal with in the past were fuses blowing for my tail lights/side markers/parking lights(a 30 minute fix with a lot of water breaks in Texas summer heat) and the window motor blowing out. Right now, I think my camshaft sensor is starting to fail(a recall but also a 30 minute fix) which I will be fixing tomorrow. Other than that, my G has been reliable!
gatorglaze
Sep 10, 2015 12:03 PM
johnadlertech
Accessories
Sep 8, 2015 11:57 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
