Canada Serving Canada.
wouldnt reverse
Old Jan 6, 2007 | 03:27 AM
Godfather's Avatar
wouldnt reverse
hey guys,
it was soo nice outside today so i wanted to take my car out....i started it n it was good..i put it in the reverse, but it was like something was stoping it...the car was not moving at all even if i give it gas. The hand break was off, and when i gave some more gass, like really LOTT...than i heard a sound from the passenger rear and than it moved....No idea what it is, but its scarring me now
Old Jan 6, 2007 | 07:50 AM
GEE35FX's Avatar
Originally Posted by Godfather
hey guys,
Sounds like your emergency was siezed Manbir. Might be an idea to check it out if it occurs again.
Welcome back to Ontario . Hope you had a good time on your trip.
Old Jan 6, 2007 | 09:10 AM
RBull's Avatar
Rated M
If the ebrake was on then as Wayne said that was likely the culprit. Since the noise was in the rear its even a better bet that was the problem. It's a good idea never to put the ebrake on if the car is not going to be moved for many days or weeks. It's almost guaranteed to seize.
Another potential reason is if your car was wet when it was put away the brake pad could have slightly seized on the disc. It would have required a good amount of force to break free so the car could roll away forward or background. If possible try and put away when dry.
My car with the Brembos is especially bad for this happening. I'll even ride the brakes for a few extra seconds before parking to reduce the problem.
Old Jan 6, 2007 | 09:16 AM
GEE35FX's Avatar
Thats a good point Deane concerning the wet brakes. That could have caused the calipers to sieze up. My truck does that sometimes .
Old Jan 6, 2007 | 09:27 AM
RBull's Avatar
Rated M
^it's a very common situation around here. It might be more prevalent with our Coastal humidity.
If I wash any of the vehicles I always have to drive them a bit to avoid it.
Old Jan 6, 2007 | 12:35 PM
akrus's Avatar
i would suggest not storing your car for any period of time with the parking brake on. Just leave it in gear and use some sort of chock such as a wood block, in front and behind one of the tires. Assuming you're parked on fairly flat ground, you won't have any problem with your car rolling away.
Old Jan 6, 2007 | 12:59 PM
Balzz's Avatar
Happens to me when it rains overnight and the car is outside. I'm not worried.
Old Jan 6, 2007 | 02:38 PM
Godfather's Avatar
Hey,
thanks for the help guys, apprecaite it. Its a AT tranny but i'm so used to putting on the foot break that i do it everytime i turn off the car. i did get a car wash before i parked the car in the garage a week ago. so it makes sense
thanks
Manbir
Old Jan 6, 2007 | 05:36 PM
Msedanman's Avatar
O.F. Administrator
hey guys,
M.,
I'd say all the brakes stuck to the rotors.....which will happen especially if you put the car away wet.
Next time you wash it to put away, drive it for a little way to warm the brakes up to allow them to dry properly.
C.
Old Jan 6, 2007 | 05:58 PM
RBull's Avatar
Rated M
^+1. Also might want to think about using the foot brake every time you park it. Unnecessary IMHO.
Old Jan 6, 2007 | 06:09 PM
Msedanman's Avatar
O.F. Administrator
Absolutely correct, Deane.....applying it for just sitting in the garage only makes it worse..
C.
Old Jan 6, 2007 | 06:19 PM
GEE35FX's Avatar
For sure, in the 2 years I had the 05 I only used it once and that was on one of those radically sloped side streets in Halifax .
Old Jan 6, 2007 | 06:32 PM
RBull's Avatar
Rated M
You seem to remember those streets well Wayne. They are pretty crazy downtown. I used to run and work downtown and got in some good workouts. Coming up into my subdivision its similiar.
I'll never forget many years ago my parents owned a '76 Maverick 3 spd std. My sister had just learned to drive and was so proud she could drive downtown with it, and bragged she didn't need to use the brake on an uphill. The clutch was replaced after about 2 months of her working downtown. LOL
Old Jan 7, 2007 | 01:45 PM
Godfather's Avatar
ahahah,
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
quikrotary
2nd Gen (V36) Sedan
11
Nov 19, 2015 05:14 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
