Canada Serving Canada.
Need Help with Headlights !!!!!!
Old Apr 14, 2007 | 11:58 PM
B_willy's Avatar
Hey all. I just upgraded my headlights to the 06 from 03. I am having quite a bit of diffuculty now. First of all, my daytime running lights don't work (Canadian G). Second, is that my driver side turn signal is engaging in the fog light area and not in the turn signal area. So pretty much the turn signal on the driver's side is turning on in the fog light area. But only happens when the lights are not on. When I turn the Projectors on, the turn signal is working where it's suppose to be. Any help or input would be greatly appreciated.
Old Apr 15, 2007 | 12:39 AM
God|ZIlla168's Avatar
you can't just slap on the 06 headlights you need to rewire it, I had mine done.
Old Apr 15, 2007 | 12:53 AM
B_willy's Avatar
where did you get yours done ? and what is suppose to be re-wired ?
Old Apr 15, 2007 | 01:30 AM
Gam3's Avatar
umm im pretty sure its plug and play...you dont have to "rewire" nothing ..its just a direct swap
Old Apr 15, 2007 | 02:32 AM
Finiti's Avatar
Not plug and play for Canadian G's, you have to do some rewiring for the signal lights and the daytime running lights.
Old Apr 15, 2007 | 03:34 AM
pretty much all the wires need to be rewired inorder to be canadian specs, I had a write up for half way then I got so busy with ork that I had it done by larry a local member that is located in ottawa. Larry was the original guy who helped me but I don't hafe his contact anymore. You local mechanic who is good with electronic should know how to rewire it as well.
Old Apr 15, 2007 | 07:47 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Just a suggestion....
Maybe B_willy could check out your wiring?
Old Apr 15, 2007 | 11:00 AM
I would but the lights are now with my body installer car will be dropped off Monday morning and will finally have my bumper lights and a few other stuff install and be ready for the next meet
Old Apr 15, 2007 | 11:17 AM
B_willy's Avatar
Was that your top secret bumper at speedstar ?
Old Apr 15, 2007 | 11:22 AM
B_willy's Avatar
Would the dealership be able to do the rewiring ? and if so do you have any idea how much it would cost ?
Thanks
Old Apr 15, 2007 | 11:29 AM
yeah I know albert so I got a good deal. And I will doing other stuff to the car later on. The NSX outside is my mechanic's car so he knows how to treat my car well. And the 350z nismo bumper he has right now in the shop will be going on my bros car.
Old Apr 15, 2007 | 11:45 AM
B_willy's Avatar
Cool. Do you know if the dealers would be able to rewire it ?
Old Apr 15, 2007 | 11:53 AM
I am sure they can but they will charge an arm and a leg. Take it to canadian tire they do daylight conversion all the time for people buying cars in the us.
Old Apr 15, 2007 | 11:56 AM
B_willy's Avatar
thanks for the help man. Gonna call the dealer tommorow and ask how much the will charge me, if they charge too much then I will go to canadian tire.
Old Apr 15, 2007 | 02:23 PM
35bills's Avatar
Where are you located? I would stay away from Cdn Tire...too many bad stories I hear about their service.
Check out www.simoneperformance.com . Give Vic a call and see if he can help you out. Its much cheaper than the stealership!!!
