Where I get a set of used rear brake dust shields
I wonder where I can get a set of the rear brake dust shields for the left and right sides? Used ones are fine. These are the ones that would fit 12.1" rear rotors. Thanks for your help.
The problem with someone having to remove the rear dust sheilds to install a BBK is that they are usually cut off and probably bent to hell. The rear dust sheild is actually 2 pieces spot welded together, (sheild and backing plate for parking drum/brake)
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
