Canada Serving Canada.
Winter Tires 07 6MT Coupe
Old Jun 25, 2007 | 10:57 PM
koloman's Avatar
Yeah I know it's depressing to talk about winter right now, but I'm starting my search for winter tires. I searched the forum, but there's a patchwork of questions and answers on this topic.
I can easily put up with the TPMS staring at me, I already drive with the VDC off all the time, so I'm thinking about picking up a set of regular black steel rims and some good winter tires.
My question though is what tire sizes have worked best? I'm going to try and put as high of profile tire on as I can, but I want to make sure the rims clear the brakes.
Old Jun 26, 2007 | 07:01 AM
whatacar's Avatar
Tom Kjeldsen - Tiretrends" <tlk@tiretrends.com
Gave me lots of great advice and service. I ended up buying locally because of a price match.
GL on your search. Some OEM 17" rims usually cost the same or a little bit more as steelies and look much better. FWIW, I picked up some sedan rims.
Old Jun 26, 2007 | 01:58 PM
cboy's Avatar
koloman, I bought a set of 18" FRD 68 (Anthracite) for my g along with some Blizzak LM-25. The Infiniti dealership here in Calgary sells this setup and I'm happy with it except I have to get new winter tires since the Blizzak only last for two winter seasons. I'm planning on getting some Toyo Garit KX because the winter weather here changes a lot and the rubber compound on the Blizzaks are really soft. If you have the $$ the other opinion is the Dunlop Winter Sport M3.
Good luck with your tire selection!
Old Jun 26, 2007 | 02:53 PM
giddyup69's Avatar
i have the following sizes on mine:
pirelli 210's
225/50/17 front
225/55/17 rear
no problems
Old Jun 26, 2007 | 04:22 PM
God|ZIlla168's Avatar
never turned vdc off in winter time.
Old Jul 9, 2007 | 09:55 AM
jasonintoronto's Avatar
on my 2003 i use:
pirelli 210's
225/50/17 front
235/50/17 rear
this was the stock tire size on the "base" z that was available in the US, so i felt comfortable with that setup.
Old Jul 12, 2007 | 01:04 AM
Woblin_Goblin's Avatar
I only turn VDC off when I need to get moving at a slushy intersection or parking lot.
If you go with 17s consider Yokohama IG721's. They're not that expensive and have a pretty stiff sidewall. I've had mine for two Alberta winters. One winter with light snow and mostly dry roads and the other winter with lots of snow and ice. Worked great in all situations and the tires are still pretty much brand new.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
NemesisGee
Aug 11, 2015 07:10 PM
multimut
Canada
Jul 26, 2015 08:43 PM
Kal Hamm
Jul 24, 2015 08:55 AM
driftsucky
Jul 15, 2015 12:38 PM
