Canada Serving Canada.
Interesting new battery technology
Old Jul 23, 2007 | 08:16 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
So, you want to drop a few pounds?
PLUS lots of capacity.
This looks like interesting technology;
Could mean some extra trunk space for me.....
Voltphreaks
Voltphreaks 12 Volt car battery. This is the high capacity/high power version, and is compatible with all passenger cars and trucks. Almost double the Ah rating of the standard Voltphreaks battery. Replace your 12 volt lead-acid starter battery with this one and save 30 to 40 pounds! Current state of the art in battery technology (safe nano-phosphate lithium).
Standard lead-acids last 3 to 5 years before needing replacement. Lithium nano-tech batteries will last 5 to 10 years. Besides saving weight, you will have less voltage drop under load, for stronger cranks. Plus it's less affected by cold weather than a lead-acid battery. In testing, we've cold cranked a BMW M3 10+ times without any issues, then left the headlights on and radio blaring for 15 minutes, and then cranked again, and the car cranked same as before!
This battery does not have the thermal runaway issues of standard lithium batteries, and is much safer. In fact, it's way safer than the lead-acid battery currently in your car, and better for the environment too! Check out more information on nanophosphate lithium technology.
Because this battery is a lot smaller than standard lead-acids, you can screw or bolt mount using the mounting flanges. We used double-sided emblem tape to mount the battery in our personal car.
Our warranty and return policy
Refunds are allowed for ANY reason, doesn't crank your car, you don't like how it looks, you just wanted to try the battery out, etc. You just can't abuse the battery (running it over, putting it in a fire, etc). So feel safe in purchasing this battery, we are so sure you will like it that we don't expect many returns!
Item..............................Specifications
Model Number..................VPHR18
Nominal voltage................12.8V
Cranking Amps (CA)...........800+ amps
Cold Cranking Amps (CCA)...650 amps
reserve capacity (RC)..........44 minutes
Capacity.............................18Ah
terminal type.......................5/16" gold plated ring
working temperature.............-22°F to 140°F
dimensions .........................8.3x5x3 inches (not including terminals/flanges)
weight...............................6.5 pounds
Old Jul 23, 2007 | 08:38 AM
RBull's Avatar
Rated M
Definitely interesting stuff. That's incredibly small and powerful.
You get a double benefit saving weight and space.
Old Jul 23, 2007 | 09:35 AM
sdnpaul5at's Avatar
Which battery are you currently running Ian? How many cold cranking amps? I was thinking of just finding the smallest battery for now in size for like $50 & just using it for the summer, I'm just hoping the lower cranking amps will be enough.
Old Jul 23, 2007 | 10:54 AM
InTgr8r's Avatar
Still the OE battery, I haven't looked up the specs....
It's not likely worth the change for me.
I'd have to modify the trunk trim panels etc.
I'd only consider it if the car became a long term keeper.
Old Jul 23, 2007 | 04:47 PM
Msedanman's Avatar
O.F. Administrator
Definitely a good lead Ian (pun intended... ), but not much time to take advantage of the 25% sale price......which finishes 24/7/07.....
Not a lot of time to research to get the sale price........
Are you going for this by tomorrow?
C.
Old Jul 23, 2007 | 09:49 PM
godmans's Avatar
I wouldn't change it since the M has the battery at the back already....
Old Aug 15, 2011 | 10:51 PM
NYT's Avatar
NYT
Finally, a battery with stock or better performance (CCA + life) and weight savings like a racing battery. However, the cost of having your cake and eating it too as almost $2,000?!
Other than an Optima red top that only saves 5 lbs is there any other option for us Canadians that can provide the best of both worlds?
Old Aug 15, 2011 | 11:03 PM
Texasscout's Avatar
18ahr? That's it? It has NO reserve capacity. I have a bigger battery in my lawnmower. My current battery (Optima 35) has is rated at 48ahr. Don't even think you can run your radio for more than about 20 minutes and still start your car.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
jsimonk
Sep 2, 2015 03:07 PM
