Canada Serving Canada.
Gord's GroundingGear!
Old Aug 10, 2007 | 09:41 PM
  #31
Garnet Canuck's Avatar
Traveling Administrator
Originally Posted by GEE35X
That change sounds very dramatic Ron. Are you sure alot of the improvement did not occur just from resetting the ECU.
I have heard a lot good things about Gords grounding kit, but usually the improvements were more noticeable in automatics.
Wayne
Wayne, when Ron was over my house earlier today, I am quite sure he stated he didn't reset the ECU until after he installed the grounding kit and took his Coupe for a drive and noticed the difference. I could be wrong, but I am sure Ron will confirm.
Old Aug 10, 2007 | 10:27 PM
  #32
spddmn124's Avatar
Originally Posted by Gobsidian
The ones that go around the back are just bolted to the Plenum bolts on either side. The ones that go into the battery box are 1 to the ground on the battery and the other goes through the main wiring harness grommet at the back corner and down to the ECU mounting bolt.
There is a grounding wire on the fronts of each of the strut towers as well.
Hope that helps!
- Ron
thanks
Old Aug 10, 2007 | 10:59 PM
  #33
Gobsidian's Avatar
Wayne
Actually I wanted to avoid the placebo effect and make sure what my butt was feeling was legit so to compensate for the ECU reset I did it before the install went for a few WOT runs without the wires installed.
Installed the wires and reset the ECU again.
- R
Old Aug 10, 2007 | 11:02 PM
  #34
Gobsidian's Avatar
Actually come to think of it as well one of my stock grounding wires on the passenger side strut tower was corroded pretty badly as well. My car only has 24,000kms on it.
Old Aug 10, 2007 | 11:42 PM
  #35
2SAVVY's Avatar
Would someone be so kind to point me in the direction where I can go and buy these wires.. BTW do they come in BLUE??
Old Aug 10, 2007 | 11:58 PM
  #36
Gobsidian's Avatar
This thread is a good place to start
https://g35driver.com/forums/showthr...=groundinggear
They come in Red, Blue and Root Beer colors I believe.
The guy you are looking for is GordGee.
- R
Old Aug 13, 2007 | 04:05 PM
  #37
2SAVVY's Avatar
Thanks Gobsidian for the link. Just got all the details from GG on how to order so needless to say I will be doing that this week. Just not sure what colour to order yet. Torn between RED and the SMOKE.
Ken
Old Aug 13, 2007 | 04:10 PM
  #38
Gobsidian's Avatar
Ken
Cool, post back with your experience Ken. I personally think the red looks pretty sharp in the engine bay!
Cheers,
- Ron
Old Aug 13, 2007 | 04:28 PM
  #39
RBull's Avatar
Rated M
Ken
Red on the silverstone.
Old Aug 13, 2007 | 05:07 PM
  #40
Mmagic76's Avatar
Just FYI when I was shopping for these, I've heard the Red and Blue would darken over time from the heat.
Old Aug 13, 2007 | 09:52 PM
  #41
Gobsidian's Avatar
Will let you know how I make out with them, so far so good.
- R
Old Aug 14, 2007 | 08:27 AM
  #42
RBull's Avatar
Rated M
- R
Probably take a long time for that to happen even if it does. No offence Mmagic76 but sounds like a wives tale.
Old Aug 14, 2007 | 03:27 PM
  #43
2SAVVY's Avatar
Went with your expert advice and ordered the RED.
Old Aug 14, 2007 | 07:12 PM
  #44
RBull's Avatar
Rated M
Ha, thanks. Nicest thing anyone has called me today but I can't promise it's true.
I'm sure you'll be happy with them. If you're going to bother with the wires may as well have a little bling.
Old Aug 14, 2007 | 09:42 PM
  #45
2SAVVY's Avatar
I figured it matched the INJEN name plate which is red along with the Infiniti on the engine cover and you are correct a little bling isn't too bad..
Not looking forward the install but i'm sure it can't be too bad.. Luckily my neighbour has a lift in his garage so it should make it alot easier.. That reminds me gotta him a 12 pack..
Kinda forgot how bad the MOD bug gets when you get started.. I think I have dropped almost 4 G in 2 weeks.. Gonna have to wait on the exhaust.. Love the look of the HKS but the FI one is sweet too..
Gordgee
31
Jun 18, 2007 07:53 PM
Gordgee
Feb 19, 2005 12:48 PM
Gordgee
Tuner & Dyno
30
Mar 23, 2004 02:21 PM
Gordgee
Intake & Exhaust
Jan 26, 2004 09:04 PM
