Sqeaky Brakes and other fun noises....
Originally Posted by Asad_A203
Are you using OEM pads? Nissan said my pads were at 80% but the squeeks sure are annoying; wondering if replacing them this early will stop it.
Also, when the wheel is turned to the right (even slightly) there's an intermittent noise as if there is something scrapping on the metal/pads. Very strange and VERY ANNOYING!
hello BB_Sam,
the reason why you are getting that noise is probably because the mechanic who put your pads on didnt do a good job on remove the dirts and/or put enough grease to lubricate between parts.
i had the exact same problem earlier it's now noise-free after i had them re-serviced..
hope this helps.
hope this helps.
I went to a local Nissan dealership and was told that with all non-OEM brakes i'd get some noises... he couldn't explain the right turn sound (other than maybe some dirt being lodged in there).
My mechanic says that Nissan is full of it ... but that I should drive the car for a few more days to see if the debris will either fall out or burn itself off.
I'm skeptical that any of this will work but doing nothing is VERY cost effective...
Originally Posted by BB_Sam
Don't mean to rub it in... but, as you'll see from the photo, there's reason to brag here!
http://toronto.en.craigslist.ca/tor/car/678960058.html
Originally Posted by SwivelMan
Doesn't take much to pull off the wheel, pull the pads and inspect/clean things up. Even *I* can do it.
Originally Posted by Mmagic76
What are you moving on to Brad??
Hey, isn't this for sale?
I suppose this is because of the American used cars that are flooding into Canada. It's almost not worth taking the $$ hit to sell.... But even at the lowered list price of $15,500, I'm getting very few serious inquiries...
I'm going to do a surprise visit and have him just clean the pads and grease things up.....
Anyone else have problems with NewTek pads?
Hey Brad did you happen to sell a coupe 2 years ago?
Okay, so it appears that my problem for all noises are defective front pads. My mechanic looked at them and said they're not performing correctly and they need to be replaced. They are NewTek which he says aren't that good. Since these are relatively new, they are being replaced under warranty but I'll probably spend a few extra $$ to put Wagners on.
So Brad, I have to ask...what are you doing with those sport wheels? Going with the car, I presume? Love to talk you out of them if you have another set you could put of the car for sale.
