Headlight Covers! Cleaning
Originally Posted by shilohap
Can anyone recommend a good product for bringing headlight covers back to life?
http://www.meguiars.com/estore/product_list.cfm?sectionname=Consumer%20(Meguiar's %20Brand)%3EClear%20Plastic%20Care§ionID=15101
Originally Posted by 35bills
Meguiars PlastX...you can get it at Can Tire. Great stuff!!!!
Cheers!
depending on how bad they are you might need to wet sand them with an 8-10,000 grit sandpaper then use the Plastic-X with a high speed buffer. I did my VW Golf 2 yers ago the headlights were so bad you couldn't even see inside because of all the hase and road grime, by the time I was done it looked like I had bought new headlights infact my wife didn't believe me when I showed her the finished result. If yours are not that bad use a wool pad and a buffer attachment on your drill with the plastic-X and it should turn out fine.
Colin
Originally Posted by Msedanman
+1.....great stuff.
Colin
Colin
Originally Posted by Asad_A203
I like PlastX as well; but would a LC yellow pad with some compound work better? I have some annoying swirls I can't get out with PlastX.
Plastex has its limits for sure. For deeper abrasions, you'd have to go with a pad and compound first.....
C.
Hey Asad, I would be careful with compounding. A yellow pad sounds a bit much to me. I would start with white and move up to orange then yellow if needed. I've taken lots of swirls out of tail lights with white/ssr1
Thanks for the advice; will give it a try with a white pad and SSR 1.
One other thing I am bit suprised by is on Autopia; apparently our paint has a very hard clear coat but I don't know why then it is so proned to chipping and swirling. I have a few troubled areas on my paint (when I told my stupid dealership to buff out a scratch in the clear; they put touchup paint and tried blending it in; looks horrible) and was wondering if SSR 2.5 with a yellow pad would be sufficient if our clear is as hard as everyone is saying. I used some Scratch X and it got out some of paint/compound but alot of it still remains.
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
