Canada Serving Canada.
Looking for a good muffler shop in the GTA...
Old Jun 15, 2008 | 03:58 PM
brownfv's Avatar
Hey guys i am wondering if anyone knows of a good muffler in the GTA to help me with some custom work.
I have decided that the exhaust i am going to get for my FX35 will be the Bassani Exhaust made for the 350z. the only problem is i need some custom work on the Y-pipe to clear my AWD casing
basically what i need done is some extensions at the beginning of the y-pipe on each end, and then an extension on the piping before the tips so they can clear the bumper. below is a diagram with the circled areas where i need the custom piping work.
If anyone can direct me to a good reputable place it would be really appreciated.
Old Jun 15, 2008 | 04:43 PM
fais's Avatar
http://www.zoromuffler.com/home.html
I go to these guys, great service and they do good work. You can stand inside and watch them as well. I had them install the coupe midpipe on my sedan, it needed an extension welded on it to fit properly.
Old Jun 15, 2008 | 05:28 PM
brownfv's Avatar
Thanks for the link i will definitely check that place out. did you go to the mississauga location?
Old Jun 15, 2008 | 05:37 PM
fais's Avatar
No problem, yep Mississauga location is the one I went to
Old Jun 18, 2008 | 02:30 PM
kamikazeiG35's Avatar
Not sure what area you are in, but a great place I'd reccommend is Hot Rod Scott's. I did most of my custom 240SX work done there. Scott is a good guy and his bays all back out into the parking area, so you can stand and watch the whole process from outside (or go in and watch too). They do custom bends and pieces as well. You should talk to them. They are just south of Kipling Station on Kipling.
Just my two cents,
Al
Hot Rod Scott's
Contact : (416) 236-0677
Address : 815 Kipling Ave, Etobicoke, ON M8Z 5G8
http://www.canpages.ca/page/3173199.html
Old Jun 18, 2008 | 03:02 PM
noodleman's Avatar
^^^ +1, I had my exhaust installed there and head them fix a tip that was bent during shipping. Great bunch of guys and very pleasant to deal with.
Old Jun 19, 2008 | 01:44 PM
PDT's Avatar
PDT
+1 on Hot Rod Scott's. They did some work on my old Accord. Really nice guys to deal with.
Old Jan 12, 2009 | 10:59 AM
TorontoG35x's Avatar
Based on Fais's recommendation of Zorro I tried them out. Nissan wanted $1,200 to fix my 2004 G35X exhaust, they said the mid pipe and rear muffler needed to be removed. Took it to Zorro (Miss) and they cut out the corroded piece of pipe and replaced it for a total cost of $100 !
Great service, highly recommended.
Old Jan 12, 2009 | 11:25 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
+1 more ....
HRS did a custom install on the Magnaflow rears on my car & did great work!
Old Jan 12, 2009 | 11:26 AM
InTgr8r's Avatar
Great stuff!!!!
$100 sounds a LOT better than $1200
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
Red G Coupe
Tuner & Dyno
Jul 30, 2015 08:32 PM
igking
Jul 19, 2015 01:12 AM
