Canada Serving Canada.
Winter Driven G Owners
Old Sep 10, 2008 | 09:38 PM
Travellin007's Avatar
Originally Posted by InTgr8r
!!!! DO NOT USE SALT FOR EXTRA WEIGHT IN THE TRUNK!!!!!!
If it leaks, the salt can migrate into all the nooks & crannies & you will get corrosion.
Just having it in the trunk can also corrode electrical components & connections.
I've used granular limestone.
It's heavy for it's volume & works great if you need to sprinkle a little under the tires.
thanks for the heads up!
Old Sep 11, 2008 | 02:48 PM
CDN35's Avatar
Originally Posted by Swan
I can appreciate your dilemma...I also plan to drive my coupe in the winter but after reading some of the posts (especially in the regional forums) I’m a little more at ease, seems winter tires and a little weight in the back can make all the difference.
Concerning the issue of trunk space, I was very surprised to learn how accommodating it can be.
I play hockey (goalie) and I manage to fit all my equipment with ease, I fold down the back seats slide 2 sticks through the opening, throw my pads inside the car (back seats) and my bag fits "perfectly" snug in the trunk.
Or if you have more important things to haul...
I loaded the coupe up with 11 2-4's and made a trip to the beerstore
Good luck!
you drive the coupe and fit all that goalie equipment in the trunk? see i need to lug hockey bag around as well, plus work related bags/coaching bags on the other days and just find the trunk somewhat small, as the girl drives a coupe. but i guess if i folded down the seats it would make it a little easier.
I was leaning heavily against the sedan, but as time passes the X is starting to look like a decent alternative
Old Sep 12, 2008 | 10:17 AM
Swan's Avatar
I was getting a little nervous before I purchased the car wondering if things were going to fit, luckily they did.
As for all your equipment, you are going to be limited with the coupe in terms of other passengers...whereas with the sedan you can fit 2 more in the back seats and they have their own door. I think the sedan has a 60/40 split in the back so that also lets you throw 2 hockey bags in the trunk and other stuff on the folded seat potion (still keeps 1-2 back seats open).
Sounds like you have more stuff to carry than I do, so I would say the sedan would be your better buy, practicality wise.
toadfire
Sep 21, 2015 07:15 AM
AesonVirus
17 Inch
Sep 20, 2015 02:05 PM
carsmacked71
Sep 18, 2015 04:13 AM
DRG35R
Sep 16, 2015 05:33 AM
vstring
Sep 11, 2015 02:50 PM
