projector headlights schematics/rewiring diagrams?
Hi, just installed the 06 headlights but it's been bothering me not being able to turn on the foglights. Anyone have the rewiring instructions? I tried searching but there was a dead link for the headlight rewiring. The only instructions I found was for the blinker. Right now the daytime running lights (DRL) won't turn on.
Thank you
Thank you
Hey there - I'm in the process of re-wiring these now as well. When I put mine in, everything worked fine once I pulled the DRL fuse. Obviously the DRL don't work but all other functions seemed okay including the fog lights and signals. I'm hopefully going to get a DIY done in a week for the DRLs so if you can hold on till then I might be able to help.
I have it installed now, so if I pull the DRL fuse now it will work except for the DRL? If so how did do you remove it for now (lights goes chaotic unless I turn on the projectors)? Did you have any problems with condensation inside the headlight. It's never been opened but don't know why?
Thank you elrooko
Thank you elrooko
Yes it should but depending on your year and model, something else will go with it. In the 03.5 it is only the trunk light because they are wired on the same circut, but I heard in the 05 it is the power seat.
Pull the fuse and see what happens. You should be able to tell what else might be affected as it should say on the fuse panel cover what else is wired into that fuse.
Thank you elrooko
Thank you elrooko
master111
Oct 6, 2015 01:36 AM
