Canada Serving Canada.
Black finishing pad
Old Oct 6, 2008 | 12:00 PM
alphabit's Avatar
Black finishing pad
Can someone tell me how to detemine when to replace your finishing pad for a Porter Cable?
Also can you wash these pads? if so do you just use soap and water?
Thanks
Peter
Old Oct 6, 2008 | 12:10 PM
WhosUrBuddiee's Avatar
You can buy pad cleaner. It is only like 3 bucks i think. Its just a powder you mix in a bucket to clean all your pads.
Old Oct 6, 2008 | 03:53 PM
RBull's Avatar
Rated M
Yes, you should clean them after every use. Often with the harder pads you'll need to clean them periodically on the job.
Soap and water works fine. I've used the pad cleaner-snappy too but it's not necessary. Spin in bucket at low speed to dry.
Old Oct 6, 2008 | 05:47 PM
http://www.detailedimage.com/Lake-Co...d-Cleaner-P62/
They are only 1.49 each. You can clean several pads with one packet.
jsimonk
Dec 22, 2023 03:49 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
linedr89
Aug 17, 2015 05:11 PM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
