Canada Serving Canada.
projectors revisited - any canadian successfully installed 06-07 projectors on 03-05?
Old Dec 8, 2008 | 02:46 PM
kingrukus's Avatar
So has anyone here succesfully been able to install 06-07 coupe projectors on their 03-05 canadian spec G35 coupe?
I have heard stories of US Spec projectors not being exactly plug and play - they will fit physically, harnesses will plug in just fine, but there are issues with operation (due to different DRL circuits, etc).
If anyone has been able to successfully install the projectors, can they please let me know of any tips? Otherwise I will have a set of brand new 07 projectors for sale soon
Old Dec 8, 2008 | 03:36 PM
giddyup69's Avatar
someone had posted a solution a while back on how to install them.
Old Dec 8, 2008 | 03:37 PM
giddyup69's Avatar
2 second search gave me this:
https://g35driver.com/forums/canada/...-vehicles.html
Old Dec 8, 2008 | 04:29 PM
kingrukus's Avatar
Originally Posted by giddyup69
Ah I suck. Thanks man, extremely helpful, can't wait to work on this during the holidays!
Old Dec 8, 2008 | 08:38 PM
elrooko's Avatar
That was mine - let me know if you have any troubles. It worked great for me.
Old Dec 8, 2008 | 10:29 PM
Hossmaxima's Avatar
Good Luck with the project Phil, your car is going to look clean! Im thinking of doing some projectors myself
Old Dec 9, 2008 | 04:03 AM
G35Sask's Avatar
Got mine installed with the help of a friend. We managed to get everything working except the daytime running lights. The signals and everything work properly. I don't know enough about it to finish the job so I said good enough for the girls I go with.
Old Dec 9, 2008 | 08:18 AM
giddyup69's Avatar
i repacked elrooko's original file into a pdf so that it's more manageable. u can download it temporarily here:
http://www.filefactory.com/file/b895...r_retrofit_pdf
hopefully he can upload it to his server. this file is only about 2mb
Old Dec 9, 2008 | 09:03 AM
elrooko's Avatar
it's up there now
http://www.thedunphys.ca/G35/G35_projector_retrofit.pdf
George
Old Dec 9, 2008 | 09:15 AM
RBull's Avatar
Rated M
Wow, that is a lot for a light change.
Old Dec 9, 2008 | 09:32 AM
elrooko's Avatar
Maybe - I think it is worth it. With the instructions, the average guy could proablly do both headlights in a couple of hours going carefully and taking their time. Now that I have been through it once, I probablly could do both in an hour.
Old Dec 9, 2008 | 11:31 AM
STCLAIRWEST's Avatar
hey elrooko how much would u charge me to do this on my car?
Old Dec 10, 2008 | 10:23 AM
elrooko's Avatar
one hundred billion dollars
Seriously - since I'm in Ottawa and my car is stored for the winter, I'm not sure how I could test that they work assuming you mailed me your headlights and I would send them back.
Old Feb 5, 2009 | 06:47 PM
Doruk's Avatar
i pmed you elrooko if you can respond it would be so much appriciated
to the rest, hi guys, i am getting one from usa too just a quick question, if i put a very dark tint on my sensor and if i keep my settings at auto would my lights be on all the time so would i get rid of all turn signal and drl problems??
Old Feb 5, 2009 | 07:00 PM
Gam3's Avatar
i installed them...only thing you had to do is use the ballast from 03-05...no need to rewire anything
